Old 02-23-2022, 02:08 PM   #1
61hawk
61hawk's Avatar
Front Sway Bar Hitting Tie Rod Ends and Adjusters
So I swapped my manual steering box to a power steering box this morning and now I notice that my tie rod ends and adjusters are hitting the sway bar if I go past about 1/3 turn. CPP 1-1/8" sway bar. Don't know if it did it before with the manual box. Everything looks right, but obviously not.
Straight ahead:
Right turn, drivers side hits:
Left turn, passenger side hits:
61hawk is offline   Reply With Quote
Old 02-23-2022, 03:15 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Front Sway Bar Hitting Tie Rod Ends and Adjusters
Is that at ride height? You can sorten the sway bar end links, but at ride height it may not be an issue.
Probably why you never noticed it before.
Old 02-23-2022, 03:31 PM   #3
Southcity
Southcity's Avatar
You need to have the suspension under full load which is not going to happen without a motor in there. You might be able to stack weights to mimic a motor but I personally would wait until you have it under full load (motor, sheet metal etc), then asses. It will most likely be fine. Also, don't forget to install the the a-arm upper/lower bumpstops.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 02-23-2022, 04:05 PM   #4
61hawk
61hawk's Avatar
That makes sense, thanks... I guess adding 800-900 pounds to the front may change things.
Old 02-23-2022, 07:40 PM   #5
bigmoe
bigmoe's Avatar
Hmm. I would think it needs to clear through the whole range of movement. What if you go over a hump and the front suspension stretches all the way up?
I put the CPP 7423 1 1/4" on mine. Did you use the right frame brackets? They come with two optionals.
bigmoe is offline   Reply With Quote
Old 02-23-2022, 08:52 PM   #6
61hawk
61hawk's Avatar
Actually this is the same as yours. It came with two mounts, short and tall. I used the tall ones.
Old 02-23-2022, 10:24 PM   #7
bigmoe
bigmoe's Avatar
Tall ones for stock height. Short ones for drop spindles.
Old 02-23-2022, 11:24 PM   #8
61hawk
61hawk's Avatar
Yep, I used the tall one. From the response here and I've talked to a couple other people and all have said that once I get some weight on the front end the sway bar will sit lower and clear the steering linkage.
Old 02-24-2022, 02:22 PM   #9
Southcity
Southcity's Avatar
^Corrrect^, and don't forget to install upper/lower bump stops on the a-arms, highly important for full compression/droop situations when driving, putting vehicle on lift etc.
