Old 02-28-2022, 05:57 PM   #1
stepsider
stepsider's Avatar
Question Dash/ steering column question
Am I going to have to drop/lower the steering column to put in my dash panel ??
stepsider is offline   Reply With Quote
Old 02-28-2022, 06:17 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Dash/ steering column question
Yes. I usually remove the band clamp on the engine side of the firewall and remove the clamp from the underside of the dash, and let the column droop down.
pjmoreland is offline   Reply With Quote
Old 02-28-2022, 06:18 PM   #3
leftybass209
leftybass209's Avatar
Pretty much. I was able to loosen the column strap bolts enough to get mine in, but it was just old original parts i wasn't worried about scratching. Had it been new, there's no way i'd trust not scratching the column, dash, or gauge housing.
if you slide your seat forward the wheel will rest on it, if you do remove the column mount. That'd give you a lot of clearance.
leftybass209 is offline   Reply With Quote
Old 02-28-2022, 06:26 PM   #4
BASE
BASE's Avatar
I didn't have any trouble with leaving the column in place. You do want to tilt the top out first, when removing, and set the bottom in first when installing. Mine is a manual non-tilt column though, so maybe it has a little more room?
BASE is offline   Reply With Quote
Old 02-28-2022, 06:27 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
It depends if you have a tach or not. I have installed a non-tach without dropping it but you are probably going to scratch the paint on the column or gouge the dash pad if you don't.
Don't know what year your truck is but either way you will have to remove the pedal stop plate underneath. Then loosen as far as you can, but don't remove the two bolts in the column support bracket. If If you put your hand up above the clutch/brake pedal bracket you can feel the ends of the bolts. Just unscrew them until they are even with the weld nut on the top. That should give you enough room. ( put a towel or shop rag over the column to protect it).
LockDoc
Leon
Old 02-28-2022, 10:22 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I’ve removed and replaced a tach dash without scratching anything and without moving the column.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
