Old 03-02-2022, 06:35 PM   #1
cwcarpenter98
cwcarpenter98's Avatar
Rear Shock Relocation for Stock Height
So I like the way this rear shock relocation was done by Frizzle_Fry http://67-72chevytrucks.com/vboard/s...05&post4730005
My question is, has anyone done this with a stock height truck, and how has it worked for you? Were you able to use the factory rear shock, or did you need to change shocks?
Again, I'm keeping my truck at stock height, so I'm wondering if it's worth the effort or only good for lowered trucks.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-03-2022, 11:46 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear Shock Relocation for Stock Height
It's worth the effort.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2022, 12:20 PM   #3
cwcarpenter98
Thanks, Scoti.
I won't be able to start on it until the summer, but I'll report on how it goes then
Christian Carpenter
Old 03-03-2022, 05:18 PM   #4
SpudWrench
SpudWrench's Avatar
CW ill be drawing up a rear bracket for my 65 c20 to use at stock height. Plasma cut. Can do 3/16 and up. ill let you know when its done. Im using my own truck for fit testing. Might be able to hook you up
Front bracket I made. Put a preliminary bend in it. Angle has not been set yet. Came out tits
http://67-72chevytrucks.com/vboard/s...d.php?t=831662
"Just do it! Dont let your dreams be dreams"
-Shia LaBeouf
SpudWrench is offline   Reply With Quote
Old 03-11-2022, 07:21 PM   #5
Pitpig
I used the no limit.net shock relocate kit on a stock height 66. You have to get taller shocks, but it cleans up rear and makes exhaust routing easier. It’s similar in function to what you referenced
Pitpig is offline   Reply With Quote
Old 03-13-2022, 01:52 PM   #6
cwcarpenter98
Please keep us updated on what you come up with.
Did you notice any difference between stock and relocated characteristics?
Christian Carpenter
Old 03-20-2022, 09:48 PM   #7
Pitpig
I never had the chance to drive it before I installed it. No limit.net site lays out all the virtues, It really cleaned up space for exhaust
