#26 |
![]() Join Date: Sep 2016
Re: 1972 K10 Ebay Truck
Weld-thru primer on all the seams and concealed areas. Reinstalled mount plate and forward cab support. I didn't like the outside shoulder on the forward cab repair panel, so I cut it down and mated it to the one piece outer floor extension panel, LMC P/N 38-7905. I've used it a couple times now, and I really like how it mates to both NOS and aftermarket outer rockers. Added approximately 20 lbs of .023 ESAB Easy-Grind MIG wire, ground off approximately 19.9 lbs of the aforementioned wire, and voila, starting to look like a truck floor again!
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
#27 |
This truck is turning out too nice to use aftermarket rockers, time to hit the NOS! Test fits like a glove.
#28 |
![]() Join Date: Dec 1999
Good progress on the metal work. Looks nice.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#29 |
Blasted rockers, masked seams and sprayed epoxy on the interior. Followed with a coat of weld-thru primer on the seams.
#30 |
Blasted the belly, coated with epoxy, and put on 2 coats of Raptor Liner.
#31 |
Houston, the yellow has landed! Cream yellow with flattening agent to match the faded 525 GM yellow. Get it a little dirty and no one will ever know
#32 |
Looks really good
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#33 |
Cleaned and primered the window frames, installed new window glass and the original trim. It was a challenge.
#34 |
Hahaha...looks great!
#35 |
Got my seat torn down and re-upholstered with new foam and a seat cover from Cars Inc. in Detroit. Original pattern for option 601 Black Cloth Trim.
#36 |
Good progress! Looks nice and fine work sir!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#37 |
Got the lower cowl and floor insulated.
#38 |
Couldn't resist shifting gears and working on wheels and tires. Wheels are CUCV 15x8.5 steelies. Blasted the rims to bare steel and pre-baked them at 450. Hot flocked a coat of Prismatic zinc infused epoxy powder, then top coated with urethane powder as soon as it flowed out. Tires are 33x10.5 BF Goodrich All Terrain T/A's.
#39 |
Finally got the engine components back from the machine shop and started putting it back together. Setting it up with 9.0:1 compression, Comp 206/212 roller cam, full roller rockers, Summit 2.5 inch iron exhaust manifolds, and a stock iron intake. Planning to use a Quadrajet for a somewhat stock look (if you can ignore the extra tall valve covers).
#40 |
![]() Join Date: Dec 2009
Is there a gear drive under that Timing chain cover?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#41 |
![]() Join Date: Jun 2019
Great project
#42 |
No, I went with a Comp CCA-7100 double roller chain. The timing cover is a Cloyes two piece with an adjustable roller cam button to set the cam lash. https://www.cloyes.com/high-performa...-timing-cover/ . I would not use this cover again, it doesn't clear a short water pump, so I had to shim the pump and the accessory pulleys.
#43 |
![]() Join Date: Jul 2008
This is a cool project and a cool story how you got it home
1965 c/10 swb 1969 c/10 lwb
#44 |
On to the greatest transmission ever built, the granny low SM465! I had a lot of slop in the driveline due to worn splines, so I replaced the transmission main shaft and the coupler sleeve. Also installed the upgraded third gear and countershaft spacer to prevent the transmission from popping out of third. I rebuilt the top cover with new shift forks and ordered the one piece shifter from Novak. Hopefully it will be a nice tight shifting transmission!
#45 |
landarts
![]() Join Date: May 2005
Excellent work on the truck. Watching the SM465 rebuild. I need to do one for one of the K20's.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 69 K20 Custom Deluxe 4x4 71 K10 Custom Deluxe 72 K20 Crew Cab Project 71 GMC Jimmy CST 70 Blazer |
#46 |
NP205 overhaul complete; with parts, tools and tech data from Torque King. I replaced the 10 spline input shaft as well as the bearings. I think a lot of that "klunk" that you hear on these manual transmission trucks is connected to the 10 spline coupler between the transmission and the transfer case. I replaced my coupler and both shafts, so I'm hoping to have a nice tight drivetrain for years to come.
#47 |
Nice work
#48 |
You are correct. I took my 70 apart and found the output shaft of the trans was worn like crazy and the coupler must have been just bouncing around in there as it was bad on both ends. I think I put a good amount of synthetic grease on my shafts of the 203-205 setup I have now. It was a long time ago.
#49 |
Frame cleaned up, powertrain reinstalled, cab back on. Starting to look like a truck again!
#50 |
Hello,
Did you like the summit exhaust manifolds? Thanks, Gene |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
