Old 02-19-2022, 02:53 AM   #76
ls1nova71
ls1nova71's Avatar
Re: Gen 3 Drive By Wire cruise control HOW TO
With aftermarket levers, you are stuck having to use the relays. Unless you use a dash mounted switch. But TS mounted levers are all backwards unless you use a factory one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-05-2022, 09:46 PM   #77
notsolo
notsolo's Avatar
I have a mid 80's gm cruise lever that had the wipers with it, not clear if I need the relays or not. It's 4 wires red yelow blue green, Green is 12 volt..from the diagram I have...is the green wire just connected to 12v or is it also need to be run thru the relays? I am using PSI harness, blue, gray, black, and a yellow to the brake switch 12v when brake applied...Thanks in advance.
notsolo is offline   Reply With Quote
Old 03-05-2022, 11:32 PM   #78
ls1nova71
ls1nova71's Avatar
Since it's a GM switch, you won't need any relays.
Old 03-06-2022, 01:16 PM   #79
notsolo
notsolo's Avatar
Thanks Eric, No luck yet. I am missing something...From a post you made 4 yrs ago..........You'll need a 4 prong brake light switch, the kind used for cruise control in the 70's and 80's. They have 2 sets of contacts, one normally open and one normally closed. The TAC ties into the cold side of the brake light wiring and the PCM side will be the other set that needs ignition power and will send power to the PCM when the brakes are not applied.
I have the ECM yellow wire going to the cold side of the brake light switch, is this backwards ...and it's supposed to be to orange brake switch wire12v.....and the green power wire from cruise switch goes to the cold side of the brake light switch....Sorry I'm electronicly challenged.
Old 03-06-2022, 06:50 PM   #80
ls1nova71
ls1nova71's Avatar
Need some more info. Do you have the pigtail that the cruise switch plugs into? Because the colors are different on it than what's actually in the lever it's self. Also, is this a DBW set up?
Old 03-06-2022, 07:55 PM   #81
notsolo
notsolo's Avatar
No pigtail, it is a DBW 2001 5.3...I wondered about the diagram I have no date on it. I did ground the lever but no go.
Old 03-07-2022, 05:28 AM   #82
ls1nova71
ls1nova71's Avatar
Do you have a cruise control brake switch? Does your PSI harness have 2 separate brake switch wires?
Old 03-07-2022, 06:05 AM   #83
Richard
I just purchased the Dakota Digital module and stalk, not the obd connection version. Hoping it is an easy solution with the PSI harness, 2013 LSA engine, trans, ecm and substituting a Corvette pedal.
Richard
Old 03-07-2022, 07:10 AM   #84
notsolo
notsolo's Avatar
I have the 4 pin brake switch, yellow brake wire, and purple tcc wire from ECM, only 1 brake switch wire. Yellow wire is on the 12volt when brakes applied, green power wire is connect to fuse box, power when key on. Checked those with a test light, they have power at the right time...tcc wire is on the 2nd set of wires on the brake switch, does wire placement matter?...Also tried red cruise switch wire as the 12v...Nothing. Thanks
Old 03-08-2022, 01:07 AM   #85
ls1nova71
ls1nova71's Avatar
Ok, I have to assume PSI is using a yellow wire for the brake input for the TAC module, so that sounds like it's hooked up correct. The TCC wire placement on the brake switch doesn't matter which wire is on which pin as long as one has power when the ignition is on and the other is hooked to the PCM. So that just leaves the 3 wires from the engine harness that are for the cruise, and the power to the switch. Power to the switch would be hooked to the green wire, set would be hooked to the red wire, resume would go to yellow and on/off would go to the blue wire. This is all 100% depending on how accurate that diagram is though, as I have never hooked any wires directly to the switch, and the pigtail wires being different colors. How are you connecting the wires? They are awfully small to be putting any kind of butt connector on, and also if it's hard wired, it will be impossible to remove the column without having to cut wires. But if that's the way you have it wired up, then check the connections of the wires to make sure they are all good connections.
Old 03-08-2022, 09:02 AM   #86
notsolo
notsolo's Avatar
Thanks, I have it wired as you said, But will double check again..Wires are soldered, shrinked and run outside the column. Next is swap out the switch, and try again.
Old 03-09-2022, 06:12 AM   #87
ls1nova71
ls1nova71's Avatar
You need to check and make sure you have power at the correct time at the TAC module plug. Have you tried slightly adjusting the brake light switch in a bit?
Old 06-29-2025, 08:33 PM   #88
WorldsCrappiestTruck
I just completed this today with the help of this thread and am thrillled. I built my harness 1 wire at a time, removing what I didn’t need to run my 5.3/4L60 E.
I had to chuckle when I opened the plastic connector for the TAC and saw pins 4.5.14 bundled together, cut off about 2” long with a label that says “for future cruise” lol. Like I planned I would be back.
Pin 6 was already wired from the brake switch as a TCC signal so I didn’t have to futz with it. 3 wires and power.
Not the hugest fan of the relay clacking but a small price to pay for cruise. ✅
WorldsCrappiestTruck is offline   Reply With Quote
