#76 |
Re: Gen 3 Drive By Wire cruise control HOW TO
With aftermarket levers, you are stuck having to use the relays. Unless you use a dash mounted switch. But TS mounted levers are all backwards unless you use a factory one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#77 |
I have a mid 80's gm cruise lever that had the wipers with it, not clear if I need the relays or not. It's 4 wires red yelow blue green, Green is 12 volt..from the diagram I have...is the green wire just connected to 12v or is it also need to be run thru the relays? I am using PSI harness, blue, gray, black, and a yellow to the brake switch 12v when brake applied...Thanks in advance.
#78 | |
#79 |
Thanks Eric, No luck yet. I am missing something...From a post you made 4 yrs ago..........You'll need a 4 prong brake light switch, the kind used for cruise control in the 70's and 80's. They have 2 sets of contacts, one normally open and one normally closed. The TAC ties into the cold side of the brake light wiring and the PCM side will be the other set that needs ignition power and will send power to the PCM when the brakes are not applied.
__________________ I have the ECM yellow wire going to the cold side of the brake light switch, is this backwards ...and it's supposed to be to orange brake switch wire12v.....and the green power wire from cruise switch goes to the cold side of the brake light switch....Sorry I'm electronicly challenged.
#80 | |
#81 |
No pigtail, it is a DBW 2001 5.3...I wondered about the diagram I have no date on it. I did ground the lever but no go.
#82 |
Do you have a cruise control brake switch? Does your PSI harness have 2 separate brake switch wires?
#83 |
![]() Join Date: Dec 1999
I just purchased the Dakota Digital module and stalk, not the obd connection version. Hoping it is an easy solution with the PSI harness, 2013 LSA engine, trans, ecm and substituting a Corvette pedal.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#84 |
I have the 4 pin brake switch, yellow brake wire, and purple tcc wire from ECM, only 1 brake switch wire. Yellow wire is on the 12volt when brakes applied, green power wire is connect to fuse box, power when key on. Checked those with a test light, they have power at the right time...tcc wire is on the 2nd set of wires on the brake switch, does wire placement matter?...Also tried red cruise switch wire as the 12v...Nothing. Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 03-07-2022 at 11:53 AM. |
#85 | |
#86 |
Thanks, I have it wired as you said, But will double check again..Wires are soldered, shrinked and run outside the column. Next is swap out the switch, and try again.
#87 |
You need to check and make sure you have power at the correct time at the TAC module plug. Have you tried slightly adjusting the brake light switch in a bit?
