03-09-2022, 10:53 PM | #1 |
Is this bulb for the HVAC
Hey guys I found a bulb dangling behind the stereo after I installed it. It's not the courtesy light as that's a bigger bulb. This bulb only comes on when the headlights are on.
Are the heater controls supposed to be lit up? Its a 78 Thanks
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
03-10-2022, 10:52 AM | #2 |
Re: Is this bulb for the HVAC
They are on my '84.
03-10-2022, 02:43 PM | #3 |
03-10-2022, 07:24 PM | #4 |
Yes there's a bulb that plugs into the heater control assy. That's probably the one you have hanging. Should be a hole in the control that the bulb holder pops into. These squares are not fun to get under the dash and mess with especially if you have factory air.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-10-2022, 07:25 PM | #5 |
Oh and mine's a 77 but it should be the same
03-11-2022, 12:53 AM | #6 |
My 75 climate control panel lights up. 2nd the thought that on an assembled dash that bulb is a PITA to get at. Might consider an LED before you go exploring. The stock bulb isn't very bright.
03-13-2022, 11:28 AM | #7 |
Thanks for the responses guys I’m gonna crawl under the dash and see if I can locate the hole. Yes I would put a blue led in there to match the gauge cluster I recently converted to led.
Excited to have this match the other lights if I can get at it. Thanks again fellas Posted via Mobile Device |
03-13-2022, 11:36 AM | #8 |
Found the hole easily from under the dash.l luckily no ac to get in the way.
Thanks again Posted via Mobile Device |
