Old 03-17-2022, 07:29 AM   #1
custom10nut
custom10nut's Avatar
Softening Door Panel Vinyl?
The vinyl at the bottom of my door panels is dried out and brittle.
Is there a way to safely soften it up, so I can get it to lay flat and glued down again?
My 70 is by no means a “Show Queen”, but these are the original panels.
I’d just like to get them to look a little nicer.
Thanks in advance
custom10nut is offline   Reply With Quote
Old 03-17-2022, 09:27 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Softening Door Panel Vinyl?
usually if they are dried out and brittle it's time to replace them , But if you want to try to save them you can try this old school fix . Vinyl is a petroleum product .
1 ) Clean the affected area with NON ethanol reg gas on a rag .
2 ) once dry use a hair dryer on low heat to soften the area using light pressure try to smooth/ stretch the area flat then apply Vaseline Original Unscented Petroleum Jelly using a dry rag . let sit for awhile then reapply heat and vaseline again if it stretches out and flat enough use contact cement to reglue it . it's a process and if your project is just too dried out your looking at replacement .
Tip : when heating the affected area keep your fingers in the air flow , If the heat is too hot for your fingers it's too hot for the vinyl .
Good luck !
Old 03-17-2022, 09:56 AM   #3
custom10nut
This is great guidance.
I agree with you that it’s probably time to replace them, but I’m an “Old School Original Parts Guy”, and want to keep the original stuff if at all possible
Old 03-17-2022, 09:14 PM   #4
MidLifer
MidLifer's Avatar
I bow to GOM and his advice, so this is by no means a challenge to it. What came to my mind when I read your post was ArmorAll. Have you tried something along those lines?
MidLifer is offline   Reply With Quote
Old 03-17-2022, 09:23 PM   #5
CG
BlahBlahBlah
Be prepared for all the Armorall haters lol (I personally dont get it). I use a product called 303 protectant, cleans and "lubes"
I have a thread here on the board for it somewhere.
Here it is .... https://67-72chevytrucks.com/vboard/...&highlight=303
Old 03-17-2022, 09:34 PM   #6
MidLifer
MidLifer's Avatar
One thing I love about this community vs. Facebook groups and other online places is how much respect members give each other. I've been here 11 years and the only times I've gotten heat is when I've deserved it.
Nonetheless, I will restate the above as "ArmorAll or another vinyl conditioner".
