03-17-2022, 05:33 PM | #1 |
Moderator
Oval Head Screw Washers
The oval head screws that hold the door panels on, they're 1/4"-20. What I can't seem to find is washers for that type of screw. Checked concave washers etc. no luck.
Anyone find a place that sells them in 1/4"? Not finishing washers!
03-17-2022, 06:03 PM | #2 |
Re: Oval Head Screw Washers
Hey Rod, the screws that were on my 62 door panels had the "washer" built in to the screw. I bought replacements that have the same head shape but are 1/4" longer. Here are a couple of pics of my old ones... I think these are available as a set to do both doors.
Like these: https://www.classicparts.com/1956-66...info/19%2D424/ Last edited by bhap; 03-17-2022 at 06:18 PM. |
03-17-2022, 06:51 PM | #3 |
Moderator
Thank you. I have a few of those from the bucket of parts I started with. I opted however to use polished oval heads on mine. Someone else is putting vinyl on theirs and I was hoping it would help with the twisting of the material.
So I'm really searching for a washer for oval head screws that would work with the indentation.
03-17-2022, 07:22 PM | #4 |
Try DK hardware.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
03-17-2022, 11:54 PM | #5 |
You should be able to find what you're looking for at any trim/ upholstery shop. Take you screw with you. I would be shocked if they don't have them. Trim shops use them for the very same reason you are wanting to use them. Keeps the material from twisting with the screw. Good Luck
03-18-2022, 12:22 AM | #6 | |
Moderator
03-19-2022, 01:22 AM | #7 |
I think they are called countersunk washers, not sure which style you need since mine were missing
https://www.mcmaster.com/standard-wa...rsunk-washers/ https://www.upholsterysupplyusa.com/...SABEgJ2afD_BwE
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
03-19-2022, 01:45 AM | #8 |
I have them how many do you need ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-19-2022, 02:00 PM | #9 |
use Au-Ve-Co part # 16015 Pic 2
https://www.clipsandfasteners.com/se...show=45&page=1 These are # 10 flush type washers and they are just a hair to small to fit over the 1/4 x 20 chrome oval head screws Pic 3 Easy remedy is to use a punch and just barely enlarge the hole to fit the 1/4 x20 screw and still sit flush with the head of the screw , Pic 4 Take a scrap piece of wood and using the punch -Punch a hole in it , this supports the washer and keeps them from splitting Pic 5 Other than these old trucks I don't know of any other vehicle that uses a 1/4 x 20 flush type washer on the interior .
03-19-2022, 03:41 PM | #10 | ||
Moderator
03-19-2022, 05:13 PM | #11 | |
https://www.dkhardware.com/flanged-n...uct-11669.html
03-19-2022, 05:15 PM | #12 | |
Moderator
