03-14-2022, 10:40 AM | #301 |
Re: 1958 Saab story
sometimes I think I should start on the passenger side first then the upgrades will be on the driver side where it will get used more, haha.
03-15-2022, 07:43 AM | #302 |
Re: 1958 Saab story
i've always been a fan of the blacked out pillars, just cleans up the lines so much.
03-16-2022, 09:56 AM | #303 |
Re: 1958 Saab story
I got up this morning and register the panel truck, so now I can legally drive to the gas station. Also finished up the body work around the headlight to make the bezels fit as best as I could. And I bought blind spot mirrors for the tow mirrors.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
03-17-2022, 08:11 PM | #304 |
Re: 1958 Saab story
I wet sanded and prepped the truck this morning before work and painted the primer spots when I got home. It was cold and foggy out this morning, and about 68 degrees when I got home. I'm very impressed with the color match from finish masters. It's just a single stage urethane.
-Josh
03-17-2022, 08:51 PM | #305 | |
Re: 1958 Saab story
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
03-18-2022, 10:20 AM | #306 |
Re: 1958 Saab story
I got up this morning and wet sanded the fresh paint with 600 grit to knock some of the shine off so it matches the rest of the paint. Then I installed the tail lights and the headlight bezels.
-Josh
03-18-2022, 12:13 PM | #307 |
Re: 1958 Saab story
man this is neat!
03-18-2022, 12:22 PM | #308 |
Re: 1958 Saab story
Power polish?
03-18-2022, 12:25 PM | #309 |
Re: 1958 Saab story
I haven't polished anything yet. I'll probably hit it with some rubbing compound, but only to get the surface scratches out.
-Josh
03-18-2022, 11:19 PM | #310 |
Re: 1958 Saab story
I bought a new wiper cowl without the vents. I painted it when I did the fenders. Installed it and put the new wiper arms and blades on.
-Josh
03-18-2022, 11:23 PM | #311 |
Re: 1958 Saab story
The lower hinge pocket showed up today, so I cut out the rotted section and trimmed the new piece to fit. Drilled several holes to make the weld stronger and ran a bead around the perimeter fit extra strength.
-Josh
03-18-2022, 11:26 PM | #312 |
Re: 1958 Saab story
I smoothed the welds with a flap disc, primered and painted everything. Before hanging the door, I cut out for the wiring harness plugs to clear like I did on the passenger side.
-Josh
03-18-2022, 11:28 PM | #313 |
Re: 1958 Saab story
I forgot I have to remove the door panel to access the top hinge bolts, so I took both panels off and sanded them down and painted them.
-Josh
03-19-2022, 07:13 PM | #314 |
Re: 1958 Saab story
I assembled the door panels, bolted on the rear doors and headed over to Madkidd's house to hang out and shake it down for any driveability issues. I did end up ordering stock loaded struts to raise the front end up a bit. It rubs in corners of you hit a bump. And she needs a bath badly.
-Josh
03-19-2022, 07:52 PM | #315 |
Re: 1958 Saab story
nice. good to get a few miles.I wondered about tir rub but figured you would have that figured out in a minute.
what did you do after lunch then......? haha. fast work. |
03-20-2022, 06:56 PM | #316 |
Re: 1958 Saab story
Gave it a bath and figured out the rear door issue. I bought an S10 tail gate to convert the latches with. While disassembling the panel truck door, I found the missing top latch. It had fallen down into the door and was held in with the threaded rod that actuates the latch. I put everything back with new hardware and made a few adjustments and everything works! Yay!
-Josh
03-21-2022, 08:57 PM | #317 |
Re: 1958 Saab story
Driving down back roads, you can smell the exhaust fumes. Running down the interstate, your eyes burn like you've been pepper sprayed. I extended the exhaust tip out and under the bumper. Hopefully that'll fix it.
-Josh
03-22-2022, 11:27 PM | #318 |
Re: 1958 Saab story
the pipe over the axle is oval shaped right? bet that took a little persuation to get the extension to fit up. I'm happy to hear you got it fixed, I was wondering about carbon monoxide poisoning and thinking how co builds up in your blood stream and takes awhile to get rid of.
03-22-2022, 11:47 PM | #319 |
Re: 1958 Saab story
It is an odd shape over the axle, but it's round at the hanger. It's angled up a bit, so I had to make a slice cut to bring it down below the bumper.
-Josh
03-23-2022, 10:21 PM | #320 |
Re: 1958 Saab story
New struts came in today. I measured the height at the center line of the front rim, swapped out the struts, took it around the block to settle the suspension and then remeasured. It raised the front end 1 3/4 inches and now the front tires don't rub. I even hit the driveway at speed to see if it would hit and I heard nothing.
-Josh
03-24-2022, 01:12 AM | #321 |
Re: 1958 Saab story
will you need to boost the rear a bit to level the truck? adjust the air bags?
03-24-2022, 01:37 AM | #322 |
Re: 1958 Saab story
I'm not sure yet. The rear shocks haven't showed up yet. I'll get those mounted and see what adjustments need to be made.
-Josh
03-24-2022, 08:36 AM | #323 |
Re: 1958 Saab story
more clearance, and probably getting less compression with new shock valving too. much win
03-24-2022, 09:17 AM | #324 |
Re: 1958 Saab story
Is the second half of this a genuine question or you trying to explain to him how to change the rear height?
03-24-2022, 09:59 AM | #325 | |
Re: 1958 Saab story
-Josh
