12-24-2021, 11:23 AM | #201 |
Re: 1972 Chevy Crew Cab “Denali”
So I see add rubbers but no strikers? When you say rubbers as in the rubber stops? Sorry new to this but your work looks amazing so wanted to ask!! Greta looking project so far.
12-24-2021, 11:37 AM | #202 |
12-25-2021, 09:20 PM | #203 |
This is a 200k Truck when finished if not more! Many High Dollar buyers with lots of $$$$
12-29-2021, 02:35 PM | #204 |
Well talked to the body man this passed weekend and he’s projecting I may have the cab back by beginning to mid March 2022. Little later than I wanted but no sense in getting upset about it. So from now till then I plan on cleaning parts and painting stuff up so when I get the cab back I can go to town reassembling. First order of business is getting a windshield and back window ordered so can be installed after paint. Went ahead and pulled some GM windshield trim out of the barn and began polishing it up. Wanted to do so in order to order the proper gasket awhile. This is 1970 trim with the 5/8 lip I believe so I’m gonna order the proper precision gasket. From what I read on the board here that’s what people are preferring to use. And I also got my new clutch linkage made up from Z bar to fork. Old stuff was too long since I moved engine forward but left existing frame bracket intact so I opted to make a new one.
Posted via Mobile Device |
12-29-2021, 10:29 PM | #205 |
Wow great job on the cab. That must have been a lot of work!! The picture made it look easy!! Haha
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
03-23-2022, 05:51 AM | #206 |
Haven’t posted any updates in awhile. Still pecking away at the bodywork. It’s taking a long time but I’m learning a lot and I never realized how much work is involved. As of now my painter is thinking mid May sometime that I would get my cab back home. No sense in rushing at this point.
03-23-2022, 05:55 AM | #207 |
Some more pics of the cab in its current state. Two weeks ago another suburban decided to follow me home. It’s crusty and has no title but I believe in a few years it will get the crew cab treatment. The guy I bought it off of actually purchased it with the intent to build a crew cab so he was happy to sell to a fellow crew cab enthusiast. 1971 burb 350, 350 turbo.. not much left inside but I did get the Chevy grille components I need for my crew cab and it also has a manual throttle option and uncut dash. Either way I was happy to save from the scrap yard
03-23-2022, 06:19 AM | #208 |
Impressive as always
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
03-23-2022, 10:45 PM | #209 |
O man another 3 door bites the dust for a over price truck.
Good luck on finishing can wait.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
03-24-2022, 03:58 AM | #210 | |
03-24-2022, 03:59 AM | #211 |
03-24-2022, 06:56 AM | #212 |
6>8 Plugless........
Your roof is looking very nice! Great score! A good suburban is getting hard to find. My wife's is pretty rusty as well. It's fixable but I have located another more rust free shell I'd like to get instead. Save a couple hundred hours on the build possibly. Her old shell will be my crew cab donor if my plan works out.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-24-2022, 07:15 AM | #213 | |
03-24-2022, 08:07 AM | #214 |
Thanks for replying.
Good call recycling all the good stuff and cutting out the bad. I cashed my burb and still haven't finding a good a replacement. Can you show a close up on how you hook up the tran to the column shifter . Thanks
03-24-2022, 07:13 PM | #215 |
low n' slo
that cab looks like it came out great
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-25-2022, 06:47 AM | #216 |
Clayton, what did you use for paint on your frame and axles? I'm really thinking about cutting my orange truck cab since it needs rockers and doing this to it this winter.
03-25-2022, 08:30 AM | #217 | |
03-25-2022, 08:33 AM | #218 |
Been working on the cab in the evening. Got everything seam sealed from top to bottom. Was excited about the drip edge as it now looks like the roof was never taken off or modified. Used 3M EZ sand bumper repair up there. Flows out nice and is self leveling. Once it’s primered and painted it should appear and feel factory. It’s also sandable so if you get some imperfections you can easily sand it. Highly recommend it.
03-25-2022, 10:20 AM | #219 |
That looks mint!
03-30-2022, 06:53 AM | #220 |
Awesome work. Takes alot of time, patients , and skill to pull this off. One day i hope to have the time and patients to build a crew cab. Kudos to you.
1970 Chevy c10 SWB twin turbo LS3. 1972 Chevy k20 super cheyenne. |
04-11-2022, 11:06 AM | #221 |
Spent the past couple weekends busy at the body shop. Got the cab in 2k primer. Some more sanding and some sealer and it be ready for paint. Also got high build polyester applied to all the doors and fenders. Gotta block them and then get them in 2k. Also got the inside of the hood stripped and in primer and paint but didn’t get a pic of it painted.
04-11-2022, 11:11 AM | #222 |
Finally pulled the trigger on the remaining three tires I needed. I’ve had the wheels since November. Powder coated white. Got all 4 tires mounted up and bolted on the chassis. Couldn’t help myself from tossing some driver quality k20 caps on there. Just perfect for the look I was going for. Definitely getting excited to get the cab mounted on the chassis.
04-11-2022, 01:52 PM | #223 |
SWB 4x4 Collector
Lookin' great bud!
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-11-2022, 07:48 PM | #224 |
04-12-2022, 09:28 AM | #225 |
Almost Satisfied
This truck is just amazing! I can't wait to see the cab back on the frame.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
