Old 03-28-2022, 12:47 AM   #26
SARBlade
Junior Member
SARBlade's Avatar
Re: My’56 Chevy Shortbox Build
Originally Posted by dsraven View Post
be slow when welding onto the axle tubes as they will get hot and end up warping when they cool off.
I had read that the GM tubes are thinner than the Ford so was going to watch that. Thanks
Kick the tires, light the fires!
My Build: 1956 Chevy 1/2 SB
SARBlade is offline   Reply With Quote
Old 04-04-2022, 12:48 PM   #27
6DoF
6DoF's Avatar
i love a good double triangulated 4-link!
have you seen the 4-link calculator spread sheet? here's a link to d/l it if not. use it, trust it, design with it. small changes can be the difference between a good set-up and a great one! i always suggest making the upper link frame mounts with adjustable holes so you can change the anti-squat if needed. set up some holes below 100% estimate, and some above, or around whatever range you are shooting for.
https://www.crawlpedia.com/files/4_link_calculator.xls
when i did the trailing arms for my 55 i wasn't going to run it, did, and 6" longer links made a HUGE change to a more correct geometry.
6DoF is offline   Reply With Quote
Old 04-04-2022, 01:31 PM   #28
SARBlade
Junior Member
SARBlade's Avatar
Thanks, yeah I was watching some vids on that, was going to pre-heat as I went to avoid that.
Old 04-04-2022, 01:35 PM   #29
SARBlade
Junior Member
SARBlade's Avatar
Thanks, yeah, I looked at a calculator on line, I need some weights, that I no longer can get because I didn't way the front end and the rear end separately. Heck, I don't even know what the truck weighs right now lol. I did take a bunch of measurements for where I want the rear to sit, and put the diff back into the correct position. I wasn't really too worried about squat since I wasn't racing it, but I guess under hard acceleration, its better the ass go down then up lol
Old 04-05-2022, 11:47 AM   #30
6DoF
6DoF's Avatar
that's where a best-guess comes in and some adjustability. play with weights and balance that you think is too much or too little and build a few sheets, should give you an idea of what's reasonable in the middle for mounts.
another thought, i've always gone on the theory that the upper to lower links should be ~30deg or more vs the upper links to the frame or each other. probably either will work, and my double triangulated 4-links have been in jeeps.
Old 04-05-2022, 04:28 PM   #31
joedoh
joedoh's Avatar
everybody got a 56! I need to work on mine.
me too, i have done a bunch of 4 links on bagged trucks with upper triangulated 4 links and that is the rule of thumb i used.
Old 04-06-2022, 03:25 PM   #32
6DoF
6DoF's Avatar
doing the bags was nice, only having to account for 1/3 the travel and limited articulation was great!
