![]() Join Date: Aug 2017
Air Ride - Control Arms
Good morning everyone.
So I've had my 65 bagged for over 4 years now and have been running cupped lower arms and stock rebuilt upper arms the entire time. Very little issues but it's time for a change. I'm trying to get some feedback on control arms the air ride community are using or have suggestions. The truck is still running stock spindles and drum brakes which will be upgraded along with this. I'm currently looking at Porterbuilt, CPP, Choppin Block, and heard about MMW but I don't see anything for my year. I'm not looking to lay frame, as I'm currently almost lay the crossmember. So that level is perfect for me. Drop the knowledge ![]() |
![]() ![]() ![]() Join Date: Jan 2018
Re: Air Ride - Control Arms
The suspension stuff sold for a 67-72 will most likely work for your 65.
I've got no experience with air bag stuff though, so I'm no help there
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
The main things aftermarket arms help with are adding caster, centering the wheel in the fender opening, or narrowed arms more fender clearance. They don't do anything to change the geometry for better handling unless you get Hotchkis arms that drop the upper control arm pivot point for increased camber gain but I think those are coil spring only.
You can redrill the locating holes in the stock LCA shaft by 3/4" to gain caster on the stock arms.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#4 | |
* Aftermarket arms w/Delrin bushings might be better but the OG sleeve set-up works pretty good for what it is. Poly bushings are not any better than the OE set-up & prone to creaking/squeaking. * The ability to go w/narrowed arms can be a benefit. Narrowing the track width may allow for generic back-spacing numbers commonly used on off-the-shelf cast wheels if leaning toward new rollers.
#5 | |
I was just looking for peoples experience with arms they have ran on these trucks. Again thank you and Scoti for the knowledge. Scoti always jumps in and has helped me out many times. |
I have installed CPP upper and lower Tubular arms for Air Bags. I have also installed CPP lowering spindles and a complete Rack and pinion. Not complete with whole truck, but so far the frame sits good and looks good. Fair warning though, it is not cheap adventure.
John 3:16 - Saved me... God Bless |
It's Better With Nitro
I also run a set of CPP air spring tubular lower control arms.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#8 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
If I owned a 63-66 truck I would run the Porterbuilt control arms that move the wheel centerline forward 1”.
Most bagged 60-66!trucks look like the front wheels are too far rearward in the wheel opening. Porterbuilt also offers a narrowed version.
Thank you lolife - do you have any experience with Porterbuilts? The choppinblock also offer either a 1" narrow or 1" forward or a combo of both. My plan was to purchase a 1" forward as I agree the centerline seems to be off on these trucks.
#12 | |
I wound up removing some RideTech arms (from the 1st batch they ever made) and getting PB's narrowed arms for my 64 as well. I wanted to pull the track width in a little more & his quality/customer service has always been excellent.
#13 | |
I've read and heard nothing but great things from the PB arms. I also read on a thread with someone using ChoppinBlock arms that they had rubbing issues with Firestone 2600. I'm leaning to going the same route. I know it's not cheap but my safety and peace of mind is worth it. HAHA |
#14 | |
Tubular upper a-arms (& stock 73-87 OE arms) have large/larger bushing barrels where the arm shaft pivots which can interfere w/the OE placement straight steering shaft. With the 1.5" pancaked/raised x-member under the dually, the front driver side bushing barrel is 1.5" closer to the steering shaft & can make contact when the suspension cycles. Others opt to run a multi u-joint/shaft set-up as the solution but I feel they add clutter where I was trying to reduce it. The fix for me was using the old style OE upper arm w/the smaller bushing footprint (HD arms have the same style bushings as 63-72 C10 arms) & notching it so there's clearance when air'd out. Keep it stupid simple and Dummy Low.
#15 |
No issues on my end. I run a pair of Slam Specialties 6" dia. SS air springs. I had the CCP lower control arms on my truck before the last build up, so about 15 years.
#16 | |
I’ve never dealt with Choppinblock. I know PBfab will talk to you before building anything for your truck. They want to make sure you are satisfied with their product and know all your options. They have great customer service.
#17 | |
#18 | ||
#19 | |
Posted via Mobile Device |
#20 |
following.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
#21 |
What did you end up going with?
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
