Old 04-11-2022, 11:03 AM   #1
72LB
72LB's Avatar
Grill swap
The pic is what I'm wanting to change to but has anyone swapped grills from a 88 to a 85? Is it just the grill or does the radiator support have to be changed? Also does the wiring have to be changed for the lights?
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 04-11-2022, 11:46 AM   #2
TotallyHucked
TotallyHucked's Avatar
Re: Grill swap
Unfortunately, you're looking at way more than just a grille swap, the core supports are different too. That's an '89-91 grille/core support. If you want the '85-88 style grille, you'll need the '85-88 core support, headlight buckets, headlights and maybe the front wiring harness too.
1985 GMC Sierra Classic
Chopped down wrongbed
Cammed LH6 5.3/T56/3.90
Walker Tuned
5/8 drop
US Mags
TotallyHucked is offline   Reply With Quote
Old 04-11-2022, 03:52 PM   #3
72LB
72LB's Avatar
Re: Grill swap
I wanting to change to that style pictured.
Old 04-11-2022, 07:57 PM   #4
Mathew21
Mathew21's Avatar
Re: Grill swap
5 years ago or so I bought a 1984 C10 with a lightly smashed front end. The u pull junk yard near me had a 1990 Suburban. So I used it to fix the truck. From what I remember I pulled the complete front core support (lights, grille) and the headlight harness from the donor Suburban.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 04-12-2022, 06:56 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Grill swap
I wish you were closer.
I have that style (89-91 blazer/Suburban) core support and headlights.
Shipping would kill the deal for sure.
Keith
Convert to disc brakes.
Old 04-12-2022, 07:14 AM   #6
44th Miss Inf
Re: Grill swap
Just did the same to my 84 GMC. Original core support was bad under both batteries, and had a newer style in the shed for several years.
44th Miss Inf is offline   Reply With Quote
Old 04-12-2022, 12:51 PM   #7
72LB
72LB's Avatar
Re: Grill swap
Just my luck lol.
So basically I need:
89-91 Radiator support
Headlight buckets
Grill pieces
HL harness.
Old 04-13-2022, 01:01 PM   #8
C10 AG
Will the 89-91 radiator support fit right in or will you have to make some adjustments. I want to put the same grill on my 84?
C10 AG is offline   Reply With Quote
Old 04-13-2022, 02:37 PM   #9
temp190
Re: Grill swap
I put a 90 suburban on my 83. need core support. will bolt right in. would be helpful to have harness. at least for the lights connectors, not sure if its a must, i had complete suburban so I switched everything over.
temp190 is offline   Reply With Quote
Old 04-13-2022, 05:33 PM   #10
TotallyHucked
Re: Grill swap
Ahh. Well, same thing just backwards. Gotta have the core support and everything. If you could find a parts truck/one in a junkyard, that'd be the most cost effective way
Walker Tuned
5/8 drop
US Mags
Old 04-14-2022, 12:32 PM   #11
72LB
72LB's Avatar
Re: Grill swap
I agree and am looking just haven't found any yet.
Old 04-28-2022, 10:15 AM   #12
C10 AG
This is my first project and I don’t want to order stuff and have something missing. For the harness y’all said you need at least the light connectors. Would I just order light connectors for 90 suburban? Thanks
Old 05-08-2022, 01:38 AM   #13
HOGDADDY
HOGDADDY's Avatar
Re: Grill swap
Here is some info.
https://ck5.com/forums/resources/89-...rille-swap.19/
HOGDADDY is offline   Reply With Quote
Old 05-09-2022, 08:36 PM   #14
72LB
72LB's Avatar
Re: Grill swap
Originally Posted by HOGDADDY View Post
They did a complete nose swap to a 78 and did a nice job. 81-87 you only need the radiator support and grill pieces along with the light harness or socket pigtails.
I'm starting on my 85 this week after scoring a 89 suburban rad support with the harness.
