Old 04-12-2022, 12:58 PM   #1
Braunschweiger
What kind of master cylinder is that and which one fits?
Hello community, my truck has a master cylinder for 4 disc brakes installed, but I have a disc/drum, I'm guessing it's from a Corvette, isn't it? Can I install a normal master cylinder from the 1976 truck, does it also fit on the brakebooster?
Fits the screw connection to the brakebooster?
I can't identify it.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 04-12-2022, 01:31 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What kind of master cylinder is that and which one fits?
It "looks " like a corvette or camaro master cylinder. It is a shallow depth (where the pedal rod pushes the piston).
Old 04-12-2022, 01:37 PM   #3
Braunschweiger
Thanks, does a "normal" disc/drum" master cylinder fit from the brake booster bolt on ?
Greetings Harald
My 62 build thread
Old 04-12-2022, 01:56 PM   #4
The Rocknrod
Moderator
Thats a good question, I assume it would. Depending on the master cylinder chosen.
Old 04-12-2022, 02:19 PM   #5
Braunschweiger
I'll see, I'll select a master cylinder for disc/drum that is suitable for brake boosters
Greetings Harald
My 62 build thread
Old 04-12-2022, 06:13 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Looks like the same aftermarket master cylinder on my truck. The key thing is your proportioning valve hanging off the side of the MC. If it was a kit used by the previous owner, It's probably already set up as disc/drum
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-13-2022, 01:58 AM   #7
Braunschweiger
No, it was set up incorrectly by the PO, I have now ordered an original master cylinder for a brake booster and rear drums from the '76 C10. I hope it fits on the brake booster
Greetings Harald
My 62 build thread
Old 04-13-2022, 09:33 AM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
The master should fit no problem. You might have to get a different push rod though. You will know when putting the new one on.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-13-2022, 09:40 AM   #9
Braunschweiger
Yes, I hope and think so too.
I measure it before installing
Greetings Harald
My 62 build thread
Old 04-13-2022, 11:57 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Side thought... I put one of these in line to the rear brakes. That way I can dial it in to not lock up the rears depending on the load in the back.
https://www.summitracing.com/parts/s...RoC43kQAvD_BwE
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-13-2022, 12:35 PM   #11
Braunschweiger
Good tip, I think I still have one lying around, I'll take a look
Greetings Harald
My 62 build thread
