Old 07-29-2004, 09:20 AM   #1
72sub
2WD to 4WD ?
Can a body from a 2WD Suburban chassis be put onto a 4WD Suburban chassis? I've got a 2WD '72 Suburban and I want a 4WD. I've located a solid '72 4WD Suburban and am thinking about swapping my body onto it. Any suggestions or advice on doing this?
Thanks,
Bryan
72sub is offline   Reply With Quote
Old 07-29-2004, 06:30 PM   #2
cheyenne10
cheyenne10's Avatar
very doable
Need floor cut on 2 wheeler for bolt in trans hump, I suggest new body bushings throughout and while your there repair any rust on body mounts. Biggest problem is size, its one piece and heavy. I have seen fork lift used with straps or jack and block body up and roll one out and other in or ? Probably want to clean and paint frame to some degree while its bare.
Good luck and keep us posted if you do it.
Bob
cheyenne10 is offline   Reply With Quote
