Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 01-31-2022, 02:26 PM   #26
Toro
Toro's Avatar
Re: Best compound for original paint?
I started on one fender with the original paint. I'm still using the Meguiar's ultimate compound and foam pads. I was very surprised with the results. Two separate cycles of about 5 to 6 slow passes each resulted in a nice shine/gloss. The paint has many nicks/gouges/scratches and I never intended to try and get those out, just clean it up as best as possible. I think the only issue now is that the paint on the hood that I started with isn't as sun faded as the rest of the panels on the Blazer. I'll post some pictures soon.
Toro is offline   Reply With Quote
Old 04-13-2022, 12:22 AM   #27
68bowtie
68bowtie's Avatar
Any updates?
Old 04-13-2022, 09:30 AM   #28
MikeB
MikeB's Avatar
I take back what I said above about sanding with 2000 grit as a last resort.
Even 3000 is meant to remove orange peel on multiple coats of NEW paint.
Stick with polishes to renew original paint!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-13-2022, 10:50 PM   #29
theastronaut
theastronaut's Avatar
One issue with using a really mild polish or Meguiars #7 is that it probably won't get quite all of the oxidation off- the more you lightly polish it the more gloss it will have, but it will be nearly impossible to have the same level of gloss over the whole truck. I fought this on my original paint '64 VW for years when I was using a really mild cleaner wax that never got all of the oxidation off. It was blotchy, even using an orbital and making multiple passes over the panels. An oily glaze/wax like #7 or Zymol cleaner wax would mostly hide it temporarily but after it was in the sun for a week the oils dried out of the oxidized layer and it would be blotchy again.
We bought a '74 C10 in 2020 and have been tinkering with it recently. A good bit of the paint is already faded to primer so we decided to buff it pretty hard and get all of the oxidation off. I started with 0000 steel wool and CLR on the rusty spots to remove light rust and stains, then 2000 on a thin/flexible plexiglass block to sand the heavier rust down flat, then Jescar Correcting Compound and a wool pad on a rotary to remove all of the oxidation and bring out as much gloss as possible. I went over that with a swirl remover and foam pad, then Meguiars #7 to finish it off.
theastronaut is offline   Reply With Quote
Old 04-14-2022, 12:03 AM   #30
68bowtie
68bowtie's Avatar
Thanks for sharing. That turned out great. My next project will need something similar.
Old 04-14-2022, 11:57 AM   #31
sscooter
#7 is an interesting product. It actually "absorbs" into ol school paints and will bring some life and workability into them.
I used to use it exclusively, but found that modern products actually do a better job of protecting and sealing "patina" in. Some paints don't respond to #7.
Astronaut's '74 C10 is the look/finish that I love getting out of old paint!!
Jescar powerlock, followed by Collinite Insulator wax, I have found is the BEST final seal after putting the shine back in.......
sscooter is offline   Reply With Quote
Old 04-16-2022, 01:14 PM   #32
oem4me
oem4me's Avatar
Another fan of 0000 steel wool here on the initial cleanup. Not so much a fan of CLR though. Not that CLR does not work, it's just weak. I personally use Metal Prep phosphoric acid solution by Blue Lightning and it goes to town on the surface rust without thinning out what's left of the original paint film. Polishing later with 3M products. I find that virtually any polish/compound found on the shelf at your local chain stores isn't nearly as effective as what is available to the professional through paint suppliers, or online.
IMPORTANT: The aforementioned Metal Prep is aggressive and needs to be tested first in an area not seen. NOT RECOMMENDED for metallic finishes! It kinda bites into those metallics and can streak permanently. Don't ask how I know. Doh!
I'll include pics showing a comparison between CLR and Metal Prep on UNTOUCHED original (non-metallic) paint. That is, nothing done but spray it on and wait. No rubbing except with a soft sponge to wet it out evenly.
The acid works especially well to bring back the brightness of white areas that have turned lightly orange with surface rust.
The pic of the front panel in the bed with the two bottles shows what each product does to the oxidation after about 1/2 hour of just sitting while kept wet with a sponge. Obviously, the CLR does not do much.
Old 04-16-2022, 01:19 PM   #33
oem4me
oem4me's Avatar
More pics.
Old 02-21-2025, 10:35 AM   #34
IT Cowboy
IT Cowboy's Avatar
The paint that they applied to my truck to be like the original is very thin! I do not think the previous owner ever did anything to it so I cleaned it with Claybar and iron remover first and it came out nice. I then just used Griot two step and it really brought out the original colors.
I have seen a few videos where they used denim pads to remove orange peel and bring it back but I am keeping my original style orange peel.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 08-09-2025, 10:20 PM   #35
pgreensoup
I really appreciate this thread. I read through it twice. And I took to heart to start with the least aggressive solution first.
I've gone and used Meguiar's "polish" on a fender and on the top of the cab. It shines up pretty nice, but I'm wondering if I should have used the Meguiar's Ultimate Compound which is more aggressive. So I went ahead and did half of the top of the cab first with Ultimate Compound, then did the polish after. Tomorrow I will pull out into the sun and see if the dual system works better than just the polish.
But my question is about the order of events if I end up using the Jescar powerlock, followed by Collinite Insulator wax. Should I be doing the steel wool and the CLR (or other product) first? Before compounding/polishing? Is the point of the Jescar to protect the bare metal? Maybe this is a stupid question, but I'm wondering if the order of events is as follows:
1. Wash
2. clay bar
3. steel wool and clr on spots
4. compound
5. polish
6. Jescar powerlock
7 Collinite Insulator wax
and maybe there is some grease and wax remover intermitently? Please tell me where I'm wrong. I plan to take on a 75 squarebody that hasn't been washed in at least 35 years.
Pgreensoup
Not mechanical, but learning.
75 Moss Gold C10 Custom Deluxe
pgreensoup is offline   Reply With Quote
