Old 07-29-2004, 11:08 AM   #1
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
Tire Size??
I have a '70 short bed and scored a set of 15 X 8" ralley wheels for it. These are kinda wide, but what is a recommended size tire for these? Thanks for helping the new guy. H.
Hunter is offline   Reply With Quote
Old 07-29-2004, 01:23 PM   #2
crazy longhorn
Fabricate till you "puke"
A 275/60/15 will fit the wheel nicely, or if you like a little taller....I run a 255/70/15 on the rear of my longhorn. Up front you my opt for a slightly smaller tire (275/60 rear- 255/60 front). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-29-2004, 10:06 PM   #3
Z28Owner
Z28Owner's Avatar
Can you run a 275/60 in the front? I am wanting to get all 4 the same size so I can rotate and have a spare to fit. Thanks
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 07-30-2004, 08:16 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sure you can, as long as your truck sets stock height or real close to stock.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-30-2004, 12:47 PM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I run 345-50-15 on the rear and 255-60-15 on the front. Fit nicely.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
