#51 |
Re: Bringing my Grandfather's 1972 Longbed Stepside C10 back to life
Getting the 305 ready to paint. Got new water pump mounted and have ports not being used plugged. Went with a short water pump because that's what the 307 had on it. Only needed a small spacer for water pump pulley and crank pulley to line up. Plan to paint everything black other than intake manifold and carb. I have new orange tall valve covers with Chevrolet in black. Also have a matching air cleaner. My new distributor is also black. Piecing it together a little bit at a time.
'72 C10 Long Bed Stepside Putting my Grandfather's truck back on the road: http://www.67-72chevytrucks.com/vboa...d.php?t=829659 Last edited by bwl101; 04-09-2022 at 02:15 AM. |
#52 |
Got the 305 painted today, turned out pretty nice. Going to also paint the exhaust manifolds.
'72 C10 Long Bed Stepside Putting my Grandfather's truck back on the road: http://www.67-72chevytrucks.com/vboa...d.php?t=829659 |
#53 |
Was able to get the new distributor and thermostat/thermostat housing on. Also was able to swap over the water pump pulley from the 307. Only had to use a small spacer on the crank pulley so the two lined up.
I was also able to install the reproduction heater unit which houses the new squirrel cage and new heater core. Making some headway for now. Just got the motor mounts and temperature sender in so hopefully those will go on tomorrow.
#54 |
Motor mounts and temp sender are on, waiting for new fuel pump to come in and new fastener set for the exhaust manifolds.
#55 |
Exhaust manifolds are on, prepping the carb and everything to be ready to go on once the engine is in the truck. Fuel pump I also on, just forgot to get a pic of it on. Also a slight preview of what the new valve covers will look like. Also have matching air cleaner as well.
#56 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work. You're getting closer.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#57 |
low n' slo
![]() Join Date: Mar 2009
oooo, love that flat black with orange valve covers
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#58 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looking good, almost time to install it.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#59 |
While waiting for a couple more parts to come in to finish up engine, installed a refurbed cluster that I purchased from a guy that does them and sells on Facebook. Looks MUCH better lol. Also got fuel pump installed, just need to hit it with some paint when I do touch ups.
#60 |
Great work so far, will be following along!
#61 |
Was able to put the new 3 point seat belts in and put the seat back in. In some angles they look blue in pictures, but the bases and the belts themselves are a turquoise, very close to truck color and also very similar to original belt colors. Also replaced the rear taillight and reverse light lenses. The old ones were faded and/or cracked. Also replaced rear side marker light lenses. Will replace the front ones after get done doing the engine swap so they don't get mangled by accident.
'72 C10 Long Bed Stepside Putting my Grandfather's truck back on the road: http://www.67-72chevytrucks.com/vboa...d.php?t=829659 Last edited by bwl101; 04-16-2022 at 11:40 PM. |
#62 | |
#63 |
![]() Join Date: Mar 2021
I like the idea of the 3 point seat belts but I don't really want them for my truck, they are nice tho ......
#64 | |
I ordered them a while ago, but just looking at the site I don't see the GM button buckle ones anymore? I'll try to find a part number that they associate with them.
#65 |
Got the 305 dropped in and bolted in. Need to bolt torque converter bolts back up, then get carb on and other odds and ends on before I can try to crank it up. Hopefully will be able to crank it in the next few days!
#66 | |
#67 |
Looking good, oh the anxiety of the first start!
#68 |
Got the carb on with all fuel and vacuum hoses run. Radiator/fans are installed along with alternator. Now just working on making sure wires are run to correct spots and wiring is correct for power as now will be using HEI instead of coil. Hope to have some time in the afternoon to work on it to hopefully get in a spot to be able to crank it! Last pic is just a teaser of what it'll look like with the orange accessories.
#69 |
Fired it up tonight! Thought we had the distributor 180 off because it wouldn't turn over so we swapped it. Then tried again and it blew a huge rats nest out of the exhaust. Then realized we had correct top dead center it was just the rats nest choking the engine. A few more cranks and it was running. Sounds to be in good running shape. Will get new valve covers on and all tomorrow and then to see if the trans will work properly.
'72 C10 Long Bed Stepside Putting my Grandfather's truck back on the road: http://www.67-72chevytrucks.com/vboa...d.php?t=829659 Last edited by bwl101; 04-19-2022 at 10:05 AM. |
#70 |
That’s awesome, congratulations.
#71 |
![]() ![]() Join Date: Jul 2002
Nice to hear she is running.
#72 |
Nice! Dang rats...
#73 |
Congrats man, she's alive !!!!
#74 |
Got it running pretty good, just need to find tune the timing. Was planning on taking it for a spin. Went to put it in gear... And nothing. Checked the dipstick on the trans and realized it was really low, not even showing on the dipstick. Well, 5 qts later of ATF, went right into each gear and drove pretty decent considering it sat outside for the last 12 years. It has come a long way, now just need to put the hood and cowl back on and tackle some electrical stuff to get everything back correct.
#75 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
