Old 04-16-2022, 11:38 PM   #1
Chan-man
Help Decoding a Small Block
I have a 1976 GMC Royal Sierra 1500 Long Bed. It’s more of a Frankenstein truck as it has Chevy door panels and what I believe to be a 78 carb. My issue is I went to replace the carb and a 1976 edelbrock isn’t fitting properly. I’m now wondering if the intake has been swapped or the entire engine. If it has been swapped then what type of engine and what year is actually in my truck. I took a picture of the engine code as best I could tonight and am attaching it but haven’t been able to find the vin on the block yet. Any help is appreciated and will look for any codes I can if I’m told where to look.
Chan-man is offline   Reply With Quote
Old 04-17-2022, 12:03 AM   #2
geezer#99
geezer#99's Avatar
Re: Help Decoding a Small Block
Clean that pad off better so we can read it then we can help.
What does a 1976 edelbrock carb look like.
Post a pic of it.
Old 04-17-2022, 01:14 AM   #3
LT7A
Since you are speaking of original equipment, do you mean 1976 quadrajet? Are you working toward originality, or trying to get the correct equipment for emissions? Searching online for Chevy small block casting numbers could help you start being able to decipher what is stamped into your block. As geezer said, hard to read it in the picture with the old paint and oil. Wire brush maybe?
Old 04-17-2022, 02:20 AM   #4
Just call me Sean
Just call me Sean's Avatar
Posting the picture upside down doesn't help either.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-17-2022, 08:33 AM   #5
Getter-Done
Getter-Done's Avatar
Flip for ya.
As mentioned, if you clean the paint off,
One of us could probably help you.
When you get the info, I would spray-paint the pad again to keep it from rusting.
The early bird gets the worm,
85 Chevy K-20
Old 04-17-2022, 08:54 AM   #6
44th Miss Inf
If the engine code is FCN, its an ‘84 305 4bbl, 160hp that had a manual trans from a pickup
Definitely a 77 or later block as it has the narrow pad
44th Miss Inf is offline   Reply With Quote
