#426 |
Re: My 56 build
it is so self gratifying when you lay primer over something you spent hours on and it comes out looking smooth.
looks awesome, keep it up and you'll be driving. do you have a final color picked, for the umpteenth time? lol. |
#427 |
Re: My 56 build
The color is going to be hermosa blue. It’s a factory infinity color. A dark pearl blue. Should flop nicely with all the curves on these trucks. Thinking of a metallic gray for frame and under the hood.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#428 |
Re: My 56 build
#429 | |
Re: My 56 build
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#430 |
Re: My 56 build
I use the VIAS Technology SEER system. Simple and programable. Disengages what you want and you carry a fob on a keychain instead of a key.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
#431 |
Re: My 56 build
Just as Tdishon said, it’s fob activated. I’m using the same technology to activate my door entry system
#432 |
Re: My 56 build
Ohhh that's fancy. I might stay down here with the peasants and a key for now, but saving this for the future truck that has the sexy chassis and all that.
#433 |
Re: My 56 build
Some progress. Almost done with the box, interior and one door. All I have to do is sand n sand n sand n sand … you get the idea
#434 |
Re: My 56 build
Added a license plate light.
#435 |
Re: My 56 build
Wasn’t happy with the window switches that came with my kit. They were 80’s Chevy truck style. So I went with 2000 Monte Carlo switches. The express down works too.
#436 |
Re: My 56 build
Then I started to make the wood cover for the top of my door handles. Im going to use a blue stained panel on the lower part of the door and continue that through the kick panel. The door panel and handle will be covered in tan material.
#437 |
Re: My 56 build
As always, seriously nice work!
#438 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: My 56 build
Awesome work! Is that evercoat filler? Do you plan to leave the steps smooth after paint?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#439 |
Re: My 56 build
Nice Work!! Coming along nicely! Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#440 |
Re: My 56 build
Thanks… it’s progress
#441 |
Re: My 56 build
Yes, it’s evercoat chrome -a-lite. Sands really well. Hardly any paper clogging. The steps will be left smooth.
#442 |
Re: My 56 build
Keep the pictures coming. Enjoying your build.
#443 |
Re: My 56 build
nice work.
I've been using feather-rite filler. do you know how it compares? |
#444 |
Re: My 56 build
I usually beat out the rough stuff, blast, repair any holes and dents found after the blasting, smooth the previously beat areas, get things as straight as possible, epoxy primer, fill anything that still needs filling, high build primer, wet block sand and spray high build/wet sand as many coats as needed to eliminate the low spots, then epoxy one last time and store the parts till paint time. before paint, wet block sand, spray a sealer before painting. good to use the same manufacturer all the way through so there are no problems with compatability
#445 |
Re: My 56 build
Not sure. I haven’t done any bodywork in 20 years. When I was last doing it PPG just came out with KU36 (it’s been a while!) I’ve just been taking advice from my local paint/body guy from the parts store. Guy knows his stuff… I’ve been out of the game for too long to understand current products. I plan on using evercoat glazing putty along with high build primer.
#446 |
Re: My 56 build
Ok, just curious.
Is the glazing putty a 2 part deal? Just wondering if it will sand at the same rate as the surrounding area. I've had that problem before. Waaay back the glazing putty was lacquer based and sometimes would react with the other substrates. |
#447 |
Re: My 56 build
Yes, it’s 2 part. Like the filler. I’m using evercoat glazing putty. It’s what I’ve used before anyone produced high build primer. It sands starting with 180 and is great for pinholes heavy sanding scratches and feathering. I’ll probably use it on top of my high build if needed
#448 |
![]() Join Date: Jan 2015
Re: My 56 build
been a while since i checked in.... getting a lot of word done.. lookin REALLY nice
#449 |
Re: My 56 build
Thanks, I can’t wait to see yours in gloss black!
#450 |
Re: My 56 build
Not much to show with all the bodywork. But when I’m tired of bodywork, I’ve been working on the interior. I like how the 1st handle came out with its final shape. Now to repeat the process for the other side. Last 2 pictures are plans for an additional wood accent. I plan on staining all of the wood blue to match the bed wood. First I have to plane them down to 3/8”. All the door panel and lower section of the handle will be covered in material. Planning on a rich tan (tobacco) color
