Old 06-11-2002, 11:28 PM   #1
bigjimzlll
bigjimzlll's Avatar
trailing arms?
Ok...im sure im just nuts but......my trailing arms have holes, abot 2 inch diamiteralong the length of the arms...do they all have them?? i dont remember seeing it b4, almost like someone lightend them or something
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-12-2002, 12:18 AM   #2
72 custom C-20
lightening?
Big Jim,
Of all the places I could think of to lighten a truck that would be the last!
Must be sabatoage!
here's a pic. of mine. see if you can see where your talking about.
by the way dose your's have plates like mine? want to know if that was stock.
David
72 C-20 custom/deluxe med. blue 350
64 oldsmobile F-85 deluxe 330ci.
86 KX 125 Old school, mint
Southampton, Pa.
72 custom C-20 is offline   Reply With Quote
Old 06-12-2002, 12:21 AM   #3
72 custom C-20
Plates
here's the plates I was talking about.
Southampton, Pa.
Old 06-12-2002, 09:49 AM   #4
slam33
slam33's Avatar
It's not a very smart way to lighten up a truck. You want those arms as stong as possible, no flex. If anything beef them up and find other areas to remove weight. You might loose 3 lbs by drilling out some holes but your going to loose 40% of the stifness, it's not a good trade off.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-12-2002, 02:12 PM   #5
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
My arms have the plates on the bottom, but no holes.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 06-12-2002, 02:47 PM   #6
68 Suburban
68 Suburban's Avatar
I think those plates are on C-20's and C-30's
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-12-2002, 06:17 PM   #7
Stepside
Gasser
Any unsprung weight removal will noticably improve acceleration.
Lightened trailing arms are a must, if you're racing. One of the first things we do on our modified. Properly lightening these arms is the trick. We lighten in non-stress areas, add support to the stress points. Depending on where those slots are, what your purpose is for this truck, all plays a part. Slotting the entire length, is new to me. I'd have to see a pic.
Stepside
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 06-12-2002, 06:43 PM   #8
slam33
slam33's Avatar
I think her talking about a street truck here, loosing 3 or 4 lbls off the arms will not make any noticable differance. Running it over a pot hole or a rough road will . The arm is a strees member and you don't want it to bend, thats why special trailing arms for Cameros and Mustangs are boxed for added performance. if you look at one of these arms, it's just two pieces of stamped steel that are rivited together. That plated the 20 and 30 arms becuse more strength was needed and to holed them together better. you can loose a lot more weigth somewhere else and you can improve the handling with springs, shocks, and sway bars. It's a bad idea to drill these arms. If you want lighter arms, spend the cash and go with a 4 link setup.
</A>
Old 06-12-2002, 07:17 PM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
holes and plates
Plates: My trailing arms have those plates as well........but I'm not sure what they came off of.
Holes: It is possible to drill holes (reasonably sized) in THE EXACT CENTER of a beam only to lose a negligible amount of stiffness. A good example would be the holes that are sometimes put in floor joists for plumbing and electrical conduit. At the exact center of the beam, there are no tension or compression bending stresses. On top, the beam is under compression, and down below, it's under tension. If you keep the hole small enough for the size of the beam, and the amount of weight it's expected to carry, you should be ok.
Personally, I'd be weary about whacking into my trailing arms with a holesaw if I hadn't done some precise calculations.......especially if it sees any towing or heavy hauling.
My $.05
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-12-2002, 11:02 PM   #10
72 custom C-20
plates
68 suburban,
The trailing arm plates only being on c20 and c30 would make sence, concidering this is a pic of a c20. the c10 I used to have didn't have them. so I'll buy that.
Stepside,
Unsprung weight huh? got any pictures of a properly lightened factory trailing arm? would like to see that. how much weight did you put back on with strenthening it at its stress points?
67 LS1
I am all to familar with structural loads on dimentional lumber, and the amount of material that can be safely removed. but there is on way in h@ll I'm leting a plumber, electritian or HVAC guy anywhere near my trailing arms!!
David
Southampton, Pa.
Old 06-12-2002, 11:28 PM   #11
bigjimzlll
bigjimzlll's Avatar
wait a minute..im an electrician.......lol...
Anderson,CA
Old 06-12-2002, 11:38 PM   #12
72 custom C-20
electritian
Presant company excluded.
Southampton, Pa.
Old 06-13-2002, 02:07 AM   #13
Fast68Chevy
Fast68Chevy's Avatar
you guys missed something here,.... lol..... no C30 used trailing arm rear suspension lol., only leaf spring,.all C20 trucks used welded on bottom flkat stock like that. C10 did not.
whoever drilled the holes in the arms does not need to be owning a 64-72 GM truck
good luck
Fast68Chevy is offline   Reply With Quote
Old 06-13-2002, 09:01 AM   #14
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Have you guys ever seen a swiss cheese catalina?
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 06-13-2002, 03:20 PM   #15
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
yeap, neat cars!
68SWB4x4 is offline   Reply With Quote
Old 06-13-2002, 05:47 PM   #16
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Re: holes and plates
My $.05
67 LS1 SWB is correct.
If you don't know how to calculate E, I, S or Fv, then don't do it.
bigjimzlll You may want to box yours at the ends to be safe. I would do it at 1/3 of the distance at each end, minimum or replace the trailing arms.
If one of those fails it wont be pretty.
MHO,
Denny
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 06-13-2002, 05:53 PM   #17
DennyB
DennyB's Avatar
Re: plates
Originally posted by 72 custom C-20
68 suburban,
Stepside,
67 LS1
David
Hey, I got a sawzall.........can fix you right up.....roflmao!
I.M.O.M,W,J&C
Patriot Guard Rider
Old 06-13-2002, 06:23 PM   #18
Stepside
Gasser
Yes, 72 custom C-20, unsprung weight. Yes, I have pictures and no, I will not post them. Not now. The topic was lightening, and why. I just gave a racers point of view. Your pessimism was well taken.
Stepside
Old 06-13-2002, 11:10 PM   #19
72 custom C-20
un sprung...
Stepside
Stepside,
Started a debate today in my head about this. Now whith the forgone conclution that I am not a racer, just a street guy. That if you could or have, Increece the strenth, eliminat flex and twist, and by removing material (with confidence, or should i say complex formulas) in unnessary areas, and equal the same weight, you would be an idiot not to. So I stand corrected and please forgive my pessimisim.
David
Some ruler I'd make, with all my doom and gloom
ahh come on, just post one pic. just one little pic.
Southampton, Pa.
