Trailing Arm Bushing question
Any pros or cons between stock rubber or poly bushings? Thanks
Re: Trailing Arm Bushing question
Does exactly what you think. Rubber is softer, more flex. Poly is harder, less flex. I want a more solid, less marshmallow ride, so I went with poly.
Please be patient. I’m a ford guy. This is my 1st Chevy. Previous cars: 1973 mustang convertible 2003 mustang Mach 1 Now building resto mod 68 C10 step |
#3 | |
The Older Generation
I don't think it would make a lot of difference in that application. I just wouldn't use Poly for cab mounts. LockDoc
Energy Suspension Poly Bushings with ~5yrs service life @ <10k miles.
Been stored indoors since & used for mock-ups. I would describe the surface texture as feeling like concrete.
![]() Join Date: Dec 1999
Scoti, I can't tell if you are giving a positive or negative review?
#6 | |
I use rubber replacements here usually but couldn't find anything when these were done (installed). Poly was my only option to get it going. I use factory style rubber replacements or spherical joints. Poly seems fine @ sway bars. Seems to squeak too much everywhere else. The arms in those pics were pulled off of my old Bronze/Gold 68. They creaked after a couple thousand miles (roughly a little into 1yr of service). Sounded like an old F**d truck going over uneven surfaces or turning into steep driveways.
#7 | |
![]() Join Date: Mar 2015
I think there is a misunderstanding, by some, on how these bushings work. Their are no moving parts per-say. The rubber flexes, nothing slides. (Why you set the truck on the ground before tightening the center bolt, this keeps you from preloading the bushing in one direction) The poly doesn't flex like rubber. My thought is they likely slide on the bolt. If they do flex the bushing life is very short. I have replaced a few rubber bushings on the trailing arms. Mostly they are still functional after 50 to 60 years. That is amazing life.
I press them out. Be careful not to collapse the sides of the trailing arm. I have a spacer I made to avoid this. After cleaning they typically go right in with a few taps of a rubber hammer. If you go to poly you typically have to retain the outer sleeve. So don't push is out. Drill out the rubber using multiple passes with a 1/4" drill or burn it out with a torch. This bushing proved difficult to impossible to find locally. I had to purchase from a truck vendor. |
Even ones quick to hate one Polly cab mounted but I put them on my 81 and I have noticed zero different over the original blown out ones.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Since their is no twisting motion the cab mounts are the likely "best application" of such bushings.
