Old 04-21-2022, 07:18 AM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
Anyone running 15" X 10" rear wheels
I would like to run a 15" X 10" rear wheel. Just wondering if it will fit good without modifying anything. Also what backspacing is best and offset. Thanks
Lethal Tendencies is offline   Reply With Quote
Old 04-21-2022, 09:44 AM   #2
SCOTI
SCOTI's Avatar
Re: Anyone running 15" X 10" rear wheels
Fleetside & step sides are different & use diff numbers to fit things.
67-72's are @ least 50yrs old so it's possible a different rear end housing is under the truck. The 71-72 rears are wider vs the pre-disc brake trucks. Which rear end housing you have impacts the numbers.
That being said, 15x10's will fit under these trucks. Backspacing depends on personal tastes, rear end width, & vehicle height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2022, 07:37 AM   #3
Joyridin
I do not have offsets, but 15 x 10 fits without a problem. I can almost get 12" wide tires under the truck, but the sectional width of the tires make them about 1" too wide depending on the height of the truck in the rear.
Joyridin is offline   Reply With Quote
Old 04-22-2022, 08:12 AM   #4
Grumpy old man
Grumpy old man's Avatar
The problem isn't using a 10" wide wheel the problem is what tires are you going to use that are tall enough to not make your truck look like a skateboard ?
Here is the best tire / speed /rpm calculator I've found yet ,
https://www.reillymotorsports.com/sp...alculator.html
Old 04-22-2022, 11:26 AM   #5
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Yep you can fit 10s on the back no problem. Had 15x10's on the rear of this 71 we built and flipped a couple years ago.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 04-22-2022, 11:37 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
According to what brand of wheels, I've seen 15" MAG rims make contact with top of front brake caliper. Also, if you use inside stick on weights for wheel balance, they could get knocked off by top of brake caliper too.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 04-22-2022, 01:36 PM   #7
Lethal Tendencies
Do you happen to remember the backspacing ? That is a beautiful truck
Old 04-22-2022, 03:43 PM   #8
Sim6
Sim6's Avatar
I have a 69’ with the narrower axle, 10” will tuck. 4.5 BS.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 04-22-2022, 07:15 PM   #9
yuccales
yuccales's Avatar
Wheel, cap combo looking good!
yuccales is offline   Reply With Quote
Old 04-22-2022, 09:40 PM   #10
Sim6
Sim6's Avatar
Thanks!
Old 04-22-2022, 10:46 PM   #11
CAMAROBOY68SS
3.5" is what come to my mind, but I cant recall as this was 3 years ago and didnt have the truck much longer after mounting them.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
