Old 04-23-2022, 10:00 PM   #1
leddzepp
Moderator
leddzepp's Avatar
How much work to modify a 4x4 suburban frame for a LWB truck?
Been looking for a K10/K20 chassis with no luck. Ran across a 68 or so suburban 4x4 frame. I know the wheelbase is the same as a LWB truck, but what all is involved in “converting” it to work as such?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-23-2022, 10:27 PM   #2
tutone
tutone's Avatar
Re: How much work to modify a 4x4 suburban frame for a LWB truck?
My 4x4 in my build thread is a 69 suburban frame. I had to add rear cab mounts to it. Also the front cab mount holes have to be elongated. The front rear spring hanger is different on a suburban , I would guess because it incorporates a body mount that you will have to remove.
Add bed mounts and you will be ok.
I sat my cab and bed on it after all that and there are pictures of how it lines up. I did shorten my frame , but that wont affect your project.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 04-24-2022, 07:20 AM   #3
Yep, just a matter of body mount differences to change, and you gain a rear tank!
Old 04-24-2022, 01:58 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Thanks for the info! Got some pics of the frame in question and unfortunately it’s bent so I won’t be buying it
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-25-2022, 01:29 AM   #5
57taskforce
All about them K’s
57taskforce's Avatar
If you don’t mind traveling; I’d bet Kevin (undertaker72) might have a K LWB frame. He’s a little south of Salt Lake City.
Tyler
Old 04-25-2022, 12:33 PM   #6
tutone
tutone's Avatar
Have you considered buying a later sqarebody K frame and swapping components to a 68-72 2wd frame. I know its a lot of work, but they are fairly interchangable. The appeal of 14 bolt 3/4 ton stuff makes the heavier ones a little harder to find.
:My build thread
Old 04-25-2022, 01:47 PM   #7
Caddylackn
Caddylackn's Avatar
I don't know California rules.
Do you need the title of the frame to do a frame swap? In some states, you need both the title of the frame and cab to be legal.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 04-25-2022, 02:31 PM   #8
tutone
tutone's Avatar
I suggested adding the 4wd components to the org frame as another option .As far as a complete frame swap, it may be an issue in other parts of the country.
:My build thread
Old 04-25-2022, 03:47 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Yeah he’s a little too far, I don’t have the time to make a long road trip.
I’ve considered that too, DIY4x and other companies also make hangers but it is a lot of work and a lot of money going that route. Easier for me to swap everything over if it just bolts on. I don’t really need 4wd but it will allow me to lift my truck easier/higher with leaf springs. I may just swap out my front spindles for 88-98 4” lift spindles and see where it lands.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-25-2022, 06:46 PM   #10
57taskforce
All about them K’s
I’ll keep my eyes peeled for one closer to you.
Tyler
Old 04-25-2022, 08:28 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Thanks Tyler, appreciate it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
