Old 04-18-2022, 10:51 PM   #1
chris989
blinker lever reufes to come out
What is the secret? I watched the videos and I had it out many many years ago. I need to tighten my tilt wheel and this lever refuses to budge.
Any secrets before i break something?
1989 v2500.
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 04-18-2022, 11:04 PM   #2
chris989
Re: blinker lever reufes to come out
Never mind, rotated it 360 while applying a lot of pressure and it popped out. Not sure where it aligned but it did.
Chris
Old 04-26-2022, 02:49 AM   #3
Pontiac1976
Pontiac1976's Avatar
https://bowtieguy.proboards.com/thre...-cruise-switch
This may help other.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
