04-03-2022, 05:27 PM | #1426 |
Re: What did you do to your truck today part IV
Replaced the turn signal switch on my '66 C20
04-10-2022, 05:40 PM | #1427 |
Fixed my rear LED turn signal/brake lights. Found out last night that I had no turn signal or brake lights when my headlights were on.
Spent 5 hours on them today. Got frustrated. Went to a buddies house. “Try swapping the two connections around. See what happens” …..damnit. |
04-10-2022, 06:00 PM | #1428 | |
04-10-2022, 06:02 PM | #1429 |
04-10-2022, 06:38 PM | #1430 | |
Yes. It was a screw up on the original builders part. The Tail and Brake wires were switched and I overlooked it. Everything works fine without the headlights turned on. Turn them on….and no brake lights or turn signal, but DRL are full brightness. Should have caught it. Now I have it. Swapped them around and g2g. |
04-11-2022, 05:35 PM | #1431 |
04-11-2022, 09:33 PM | #1432 |
My Sanity has left the building. The '66 is off to the painters to get the roof painted. It should be done in about a week.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-14-2022, 11:16 PM | #1433 |
Assembled and installed a Craftec cover on the ‘65. Nice product!
04-15-2022, 12:33 AM | #1434 |
Ooh, I like that. If you could, please start a thread about your installation and experience. That would be great for folks considering purchasing one.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-15-2022, 07:36 AM | #1435 |
Thanks Christian! Will do; I didn’t take any pictures during the assembly but I will grab some more of the installed product and put together a thread.
04-17-2022, 09:41 AM | #1436 |
Bought fender emblems, and installed a new thermostat. Cant get the truck to run over 140*, so purchased another thermostat to try.
04-17-2022, 02:52 PM | #1437 |
Where do you have the sensor for the water temperature gauge installed in the engine? When I first installed my electric fan, I installed the thermostat for it in the back side of the intake manifold on my 350. The fan never turned on because it was not getting hot enough because it wasn’t making contact with water. So I moved it to the thermostat housing and it started getting a proper reading. All that to say, maybe your gauge is not getting a proper reading.
04-18-2022, 07:49 PM | #1438 | |
Front of the intake just next to the thermostat housing. Edelbrock RPM intake Posted via Mobile Device Last edited by cwcarpenter98; 04-18-2022 at 08:05 PM. |
04-18-2022, 08:59 PM | #1439 |
04-23-2022, 09:17 AM | #1440 |
What AM I going to do today?
Drill holes in my upper fender shroud things to mount the emblems…..gotta talk myself into it though. |
04-29-2022, 08:22 PM | #1441 |
Took my latest project in for front end alignment, all good to a point, all systems functioning, brakes bedded, clutch a bit stiff, will take some getting used to or adjust later, corners like a go cart, only glitch, 78k mile transmission seal decided it want to leak….easy fix, new seal will be here tomorrow…
04-30-2022, 10:44 AM | #1442 |
Looks great Mike!
04-30-2022, 12:41 PM | #1443 |
Moderator
Went and got it from storage! Started right up, great drive on country roads home.
05-06-2022, 11:01 AM | #1444 |
But Found Her 25yrs Later!
Great feeling. There should be a song about that.
05-09-2022, 06:47 PM | #1445 |
Cleaned up the taillight connections.
Lights are a lot brighter now. Had to use PB Blaster to get the old bulbs out.
05-09-2022, 11:33 PM | #1446 |
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-10-2022, 06:46 AM | #1447 |
Nice TJ!
05-10-2022, 09:11 AM | #1448 | |
Moderator
05-10-2022, 09:32 AM | #1449 |
Sounds great TJ! Looks great too! Glad to see I am not the only one that uses Spray Max 2K clear coat in a rattle can!
05-10-2022, 10:44 AM | #1450 |
Sounds pretty rowdy. Not what I would expect a straight 6 to sound like.
