Old 03-31-2022, 02:06 PM   #1
Randal Barrick
1970 6 speed work in 1989
I'd like to add an overdrive on my 1989 K2500. Does the 6 speed from 1970, of the same model, work without major rework?
Appreciate all your advice.
Randal Barrick is offline   Reply With Quote
Old 04-04-2022, 12:12 PM   #2
HO455
HO455's Avatar
Re: 1970 6 speed work in 1989
Welcome aboard!
I think you have posted your thread in the wrong section. This is the lonely 67-72 Suburban section.
Ask a moderator to move your post to the 88 to 99 GMT400 section for better results.
RIP Bob Parks.
Old 04-04-2022, 02:45 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Maybe it is a mistype but none of the '70 pickups had a 6 speed transmission.
I will move your thread to the '88-'99 pickups forum.
LockDoc, Moderator
Leon
Old 04-04-2022, 05:36 PM   #4
Randal Barrick
Opps, meant will a 6 speed from a 1990 work in a 4 x 4 1989 2500?
A buddy of mine has 1990 2500 4 x 4 and it's a 6 speed.
Old 04-04-2022, 10:01 PM   #5
Just call me Sean
Just call me Sean's Avatar
If it is a 6 speed it didn't come with it stock.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-05-2022, 08:01 AM   #6
During the 88-98 truck run the manual overdrives were 5spds. Find out what that 6spd came out of. It should be possible to use it in an '89
Old 04-05-2022, 11:08 AM   #7
Randal Barrick
My friends 1990 2500 is a 5 speed, not a 6 speed as noted earlier. So is the correct description a 4 speed with overdrive or 5 speed?
So the question is will that 1990, or similar, swap into my 1989?
I'm heading down to Napa to pick up the 1989 in a few days. Will be checking everything, then heading back up to Medford. Road Trip!
Old 04-05-2022, 11:50 AM   #8
Second Series
Second Series's Avatar
I’m pretty sure it will work. Both my ’88 k2500, and ’90 k1500 have the 5LM60/NP241.
’88 to ’98 used this transmission with a few different versions. HM290, 5LM60, NV3500. From what I understand the case is the same but the internals were changed. The 5LM60 is not something that can be rebuilt at home, it has 3 rails that require a jig and the use of an oven to heat up some plastic things. The NV3500 was introduced in ’93.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
Old 04-30-2022, 03:54 PM   #9
Randal Barrick
Question: Which transmission vendor has a good reputation? Looking to buy a MG5 4 x 4 5 speed K2500 rebuilt.
Thanks.
