#1851 |
![]() Join Date: Mar 2007
Re: 53 Surburban "Family Truckster"
yeah the rain FINALLY broke so we are headed to Gilmore Car museum tonight for the season opener. It should be a big one.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1852 |
Came across this while flipping thru this months Good Guys magazine. I heard the guy that I sold it to moved to Arizona. Good to see it is still collecting hardware. Looks like he's made a few subtle changes (headlights, mirrors and a wiper arm delete). And it was NEVER on a S-10 chassis. It was a modified G-body. Close but not quite.
It caught me off guard to see it again. Still have 0 remorse for letting it go tho. I currently drive the Suburban about 3 times a week. We put about another 75 miles on it yesterday...Love driving the Suburban. Marc
#1853 |
6>8 Plugless........
![]() Join Date: Sep 2007
That's pretty cool to see one of your old builds and I'm betting you'll be loving the burb for a long time to come.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1854 |
that is cool.
it must feel good to know it is still winning awards and being enjoyed. Glad you have no remorse, and the 'Burb' to occupy your time
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#1855 | ||
Marc
#1856 |
It's cool to see it's still being loved.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1857 |
Hello again....
There are a couple changes or redo's I've done since putting miles on the Truckster. I used 1/8" ABS backers for most of my interior panels including the headliner. It worked well everywhere except the interior side panels in the back. For one, the panels warped and I didn't like how they looked. Two, I also didn't use enough glue the first time so you can see the wrinkles in the material. I also changed the hardware size so I could match the fronts with the billet finish washer. For that I drilled out the 10/32 threads and tapped them to accept 1/4 - 20. I had foam left over and I ordered another yrd of material. The new backer material will be 1/8" aluminum. Using aluminum allows the backer to conform to the shape of the body but stiff enough to hold is shape. For this I needed to remove the 3rd row seat and take out some of the other seat springs to gain access. I will take more pics as it starts to go back tougher. Marc
#1859 | |
Marc
#1860 |
Here is the current progress on the aluminum panels. I ran out of glue or I would have glued the 1/8" foam down last night.
I like how much tighter these panels hug the sides of the body. Thank you Marc
#1861 |
![]() ![]() Join Date: Oct 2014
In your third photo, the close up of the allen head and washer, where do you get those and what exactly are they called? Lastly, how or what do you use to thread them into the body?
#1862 |
![]() Join Date: Mar 2011
Marc, I agree with you, the aluminum will be a better fit...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1863 | |
On Suburban's there were already threaded 10-32 insets from the factory to attached the interior panels. It did drill those out and taped them to expect 1/4-20 bolts. I could not find the billet washers for a 10-32 bolt. If the factory inserts were not there I would have just used 1/4-20 nut-serts. Thanks Jim. I should be able to get them covered in foam and material this weekend. Then it's reassembly time. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 06-24-2022 at 11:23 AM. |
#1864 |
Thank you!!!
#1865 |
![]() Join Date: May 2007
beauty work!
#1866 |
Your welcome..
Thank you Marc
#1867 |
Here are a few pics of the final interior panels completed and installed. I was happy with the improvement.
I also decided on another improvement. Since I have been a pro a dropping the tank to gain access to the fuel pump I decided to make it easier on myself to get access to the pump without the need to drop the tank. I didn't think I had room due to the subfloor structure but since I had the 3rd seat out I took another look. This is in case of a fuel pump failure, I can remove and swap out the pump from the top side. My friends with the hotrod shop make similar access doors in all of their builds. Marc
#1868 |
More pics. The reason for the wood was to give the panel more weight and structure than just a metal panel. I used the same wood from the floor for the access door. Took more time but I was happy with the end result.
All that is left is to re-install the seats. Marc
#1869 |
Marc, came out super...Jim
#1870 |
worth it! even if you never need it again b/c you now carry that umbrella ... worth it.
#1871 | |
Thank you sir...
Marc
#1872 |
Panels turned out real nice I like how the tapered washers look. Your access cover is nice, nothing better than having access to stuff that may have issues.
#1873 |
![]() ![]() Join Date: May 2015
that turned out looking great Marc..!!!
like the access panel...to bad the factory doesnt do that on the new ones.. seems like every one that ive had to do had a full tank of gas when i needed to drop it
#1874 |
Ain't that the truth
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
#1875 | ||
We shove off Thursday to go to Columbus OH for the Goodguys show. It will be me and my two boys. My youngest has never been to a show of that size. Marc Marc
