Old 05-04-2022, 03:00 PM   #1
rayray767
Upper trim & lower trim holes
Hey guys I haven’t chimed in in a minute hope everyone’s off to a good start in 2022 with their lives and projects…
I’m doing a two tone Blazer and wanted to see if anyone could help with the hole spacing location on upper and lower moldings with any diagrams/measurements. they could text to me
Thank you in advance…
Ray…
614-949-6906
God Bless 🇺🇸..
rayray767 is offline   Reply With Quote
Old 05-05-2022, 03:35 AM   #2
1moretruck
Re: Upper trim & lower trim holes
I don't think blazers ever came with upper trim, but it has been done. I am in the process of adding upper and lower trim to a long bed truck now. I had all the trim before i drilled holes so i could check how it was going to lay out. i did have some cabs and doors with trim holes to measure from. The upper trim holes on mine are 13 1/2 inches up from body line. and the lower trim you would set the top of the trim pieces just about a 1/4 below the body line.
1972 C10 SWB 383 M22
1972 K20 454
1970 K5
1985 M1008
1986 M1008
2020 2500HD Duramax
1moretruck is offline   Reply With Quote
Old 05-05-2022, 03:41 AM   #3
1moretruck
Trying to add a pic, not sure this will work
1972 K20 454
1970 K5
1985 M1008
1986 M1008
2020 2500HD Duramax
Old 05-05-2022, 07:21 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ray check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=221881. Some two-tone Blazers have sold on Bring A Trailer that can serve as references for upper trim placement along the bedsides. A frequent mistake I see with upper bed trim added to pickups is a parallel position relative to the bed rail, which aligns the rear end of the trim too far above the reverse lamp/rear tail lamp trim.
Old 05-05-2022, 08:01 AM   #5
rayray767
Got it …. I knew I seeen them before
I even searched it but couldn’t find them .
Thanks guys for chiming in….
