Old 05-10-2022, 10:42 PM   #1
64stpside
Don't let this happen to you...
Just wanted to share this so nobody else is chasing their tail trying to figure this out. I took the truck out yesterday for a drive. All of a sudden it sputtered,i hit the gas , and died. I thought the alternator the gone bad and that the truck just drained the battery until It had no juice left. I tried to restart the truck, nothing. I turned the lights on and got to see if they were on...nothing. had it towed home. Today I figured out that there was a bad connection where the engine harness connector went into the connector near the brake booster mounted in the upper left-hand corner of the firewall. The main power coming from the battery goes through that connector and into the truck which distributes power throughout the electrical system. I cleaned the connections with some detoxit which is a really good contact cleaner I use when fooling with guitars and guitar amps. Used a little Dielectric grease on the connectors as well and put it all back together, no issues,starts right up runs as it should.
64stpside is offline   Reply With Quote
Old 05-11-2022, 05:34 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Don't let this happen to you...
Good info 64stpside. Some of those connections have been there 40 years so it's a great reminder to do some cleaning before it happens.
Old 05-11-2022, 10:37 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for the tip.
I replaced my tail light bulbs a couple days ago. I had to use PB Blaster just to get them out.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-17-2022, 11:26 PM   #4
slepysal
slepysal's Avatar
Had this happen to me a while back! Good tip a little cleaning goes a long way
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
