Old 05-12-2022, 07:03 AM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
Squeaky coil springs
My front coil springs squeak. I have sprayed Wd40 on them which helps for a little while, but the squeak returns. Truck is lowered. Does anyone else have this issue ?
Lethal Tendencies is offline   Reply With Quote
Old 05-12-2022, 08:05 PM   #2
HO455
HO455's Avatar
Re: Squeaky coil springs
If I were to hazard a guess, I believe either your springs may be moving around in the spring pockets, or you have some coils are touching and they squeak as they move against each other.
Maybe some photos will help folks get to source of the squeaks.
RIP Bob Parks.
Old 05-12-2022, 11:15 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Pig tail not located correctly in the crossmember.
Old 05-13-2022, 04:06 AM   #4
RustyPile
RustyPile's Avatar
There is lots of busy stuff under there.. Are you sure it's the springs?? Could be ball joint(s).. Upper or lower control arm shaft trunnions (there's four of those on each side).. Instead of spraying WD-40, break out the grease gun and give EVERY zerk fitting a shot.
RustyPile is offline   Reply With Quote
Old 05-14-2022, 02:37 AM   #5
psxpak
I put "grease free" graphite bushing in my 68 impala, then i found little packs of white grease in the box. apparently i was supposed to grease them before I put them in... sounds like someone is getting busy in the hotel room next door when im goin down the road.
psxpak is offline   Reply With Quote
