Old 05-16-2022, 05:17 PM   #1
rnrdthefox
rnrdthefox's Avatar
Guidance preping for paint with new Mar-k bed
I purchased a new bed from Mar-k. It appears to be excellent quality and very straight visually. My question is about paint prep. Is it feasible to shoot it with Epoxy then go straight to high build polyester? Are these beds good enough to do this? I can do a skim coat of filler if needed, just trying to save some time. Thanks.
My '53 build thread: https://67-72chevytrucks.com/vboard/...d.php?t=820467
rnrdthefox is offline   Reply With Quote
Old 05-16-2022, 05:40 PM   #2
gsinon
Re: Guidance preping for paint with new Mar-k bed
I can't speak about all paint companies, but for PPG you can't put poly primer over epoxy unless it has cured for a long time. I've seen people do it, then after paint the paint will "gas out" and it will look like the car has the measles.
PPG has a high build epoxy, VP2050, or CRE that you can go direct to metal and have epoxy qualities but it has the build of polyester.
Glenn
1951 3100, Area51
1955 BelAir, 4EVER17
1987 R10, Ethel
Copper Hill Rod & Custom
http://67-72chevytrucks.com/vboard/s...d.php?t=829856
gsinon is offline   Reply With Quote
Old 05-16-2022, 06:06 PM   #3
rnrdthefox
rnrdthefox's Avatar
Thanks for the reply. I wasn't very clear on my question. I wondering what others have experienced with these beds as far as how straight they are and if i could skip a skim coat of body filler and go straight to polyester and block sand from there.
Old 05-16-2022, 06:17 PM   #4
gsinon
Oh ok. Maybe I just misread the question.
Here’s how I look at that. For the most part the outsides are pretty good and the majority of the sides are covered by the fenders. I suspect that if anything you may want to do the inside of the sides.
To tell, wet the bed sides with a wax and grease remover and sight the length of them and see how straight they are.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 05-16-2022, 06:24 PM   #5
mongocanfly
mongocanfly's Avatar
I have a all mar-k bed here..based on what I see itll need epoxy, which means the surface needs roughed up..I'm gonna hit mine with 80g then spray epoxy..the epoxy will give me a good thickness to smooth while sanding ..but from what I've seen , the panels are in great shape..but as you know, packing ,handling , and shipping , might not have been a gentle ride..so there could be things that need fixed..
But . I'll epoxy, smooth it, fix what needs fixing, then epoxy again, smooth it, then high build , smooth again , followed by paint
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-16-2022, 06:45 PM   #6
rnrdthefox
rnrdthefox's Avatar
Ok. That's kind of what I was thinking. Just wanted to get a few opinions. Thx
Old 05-16-2022, 10:37 PM   #7
duramax55
rn rdthefox i wouldn't go less than 240 to scuff it down then go high build block with 240 to noke it down and move to 320 and 400 for singel stage paint. at any point if you see its not going to get all the low spot re shoot win high build.forgot to mention to use guide coats between grit change. guide coat help to see low spot's. go to 600 for a base coat clear coat. just how i do it. when doing high build do at least 2 coats and wait for it to flash between coats about 20 minutes better to wait a bit more than to try and rush to put it on
duramax55 is offline   Reply With Quote
Old 05-16-2022, 11:42 PM   #8
dsraven
yep, if it doesn't cure enough between coats then the first coats will offgas and create bubbles in the top coat....trust me. you can peel it off like saran wrap
Old 05-17-2022, 03:06 AM   #9
mr48chev
mr48chev's Avatar
Back in the early 80's some guys were saying that the spot welds showed up big time on Mar-K bed sides . That is the only gripe I have ever seen on them.
It's like anything you buy for these trucks, you may have to do a bit of work to get to the level of perfection you want.
My ongoing truck projects:
Old 05-17-2022, 07:12 AM   #10
mongocanfly
the mar-k panels are electro-galvanized...make sure whatever you do its compatible
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-17-2022, 08:42 AM   #11
rnrdthefox
rnrdthefox's Avatar
Good point. That was another question that I had about what type of coating it had. I'll check the tech sheet to make sure this is good with the epoxy.
Old 05-17-2022, 02:14 PM   #12
mr48chev
mr48chev's Avatar
There is more info on this PFD that you are going to want when you assemble the bed but scroll down a ways and they cover painting the electro galvanized parts. https://www.mar-k.com/PDFs/Instructi...Wood-Floor.pdf
You probably want to save that PFD to the computer as I am pretty sure you will be going back to it a few times. Found with a Google search rather than hunting the website.
The concept is sand the Zink but don't go through the Zink.
Old 05-17-2022, 09:07 PM   #13
_Ogre
_Ogre's Avatar
I wouldn't use 80g anything on any body panel with e-coat or primer on it
Start with reading the PDF mr48 posted
I'd likely scuff it with W&G remover and a scotchbrite
shop air compressor timer
Old 05-17-2022, 10:25 PM   #14
mongocanfly
I'll be using spi primers on my stuff..so I'll go with what they say..
When I said 80g and epoxy , I was thinking more of my fenders, which arnt coated ..
The mar-k stuff may not need epoxy..but if epoxy is to be used, it needs something aggressive to bite into
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-19-2022, 10:41 AM   #15
MARTINSR
MARTINSR's Avatar
I am THRILLED with the quality of the Mar-k bed. Mine got an SPI epoxy primer, done deal.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-19-2022, 11:22 AM   #16
rnrdthefox
rnrdthefox's Avatar
Thanks for this. I don't remember this document when I got the bed. I also didn't know that they had a hidden fastner option to the bed strips. I would have likely ordered those before I bought the polished stainless set from LMC. Live and learn. Thanks for all the other comments as well. Much appreciated. Thanks.
Old 05-28-2022, 09:36 PM   #17
BIGglaSS
BIGglaSS's Avatar
It depends if you are going for a driver quality or show. For driver quality, you could get by with just epoxy. My Mar-K bed still needed filler on the opposite sides of the spot welds, and tops of the rails. The vertical stake pockets took A LOT of filler!
They were not flat enough for just epoxy. I started with 80 grit on the D/A. Shot with epoxy, then filler work. Then Featherfill G2. Sealed with epoxy, then base/clear.
Polyester primer over epoxy would depend on the product you're using. I use SPI epoxy, and it is OK to put poly primer over IF you wait at least 48 hours.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 06-02-2022, 04:48 PM   #18
rnrdthefox
rnrdthefox's Avatar
Yes, I agree after spending the long weekend prepping the metal for epoxy, I noticed a few places with the spot welds that will need some work. I noticed a few large dimples in the stake pockets from the bending process that will need some work with filler.
Thanks for all the comments.
