Old 07-30-2004, 06:13 PM   #1
76bonanza
76bonanza's Avatar
oil pressure
Can you have to much? Mine sits about 30psi at idle and 45psi at 60mph is this to high?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-30-2004, 06:16 PM   #2
76bonanza
76bonanza's Avatar
Also my volt guage sits about 1/8 past 13 is that ok?
at idle with multimeter my batery is at 14. volts is that to high?
1968 c10
lowered 3" 4"
Old 07-31-2004, 12:02 PM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Your oil pressure sounds fine. While to much oil pressure costs some power (driving the pump) and can heat the oil, 45 PSI is no where near that point. Sounds like healthy engine to me.
14 volts at idle is also good, just check to see what the system voltage is at about 2000 rpm, you don't want the multimeter to go much above 15 volts. If it does, you can easily replace the voltage regulator in the alt.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-31-2004, 05:17 PM   #4
76bonanza
76bonanza's Avatar
My battery with multimeter seems to top out at 14.5ish What would be to high oil pressure?
1968 c10
lowered 3" 4"
Old 07-31-2004, 06:03 PM   #5
SanitysBane
i don't think that there is anything as to high of oil pressure. but there is to low.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-31-2004, 07:52 PM   #6
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
The number one cause of bearing failure, is over-lubrication. You can have too much pressure. Any more than about 70psi at full rpm is too much.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 07-31-2004, 11:52 PM   #7
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah, my oil stays about straight up and down, as in around 30. and my other one stays at 14.5. the main thing to watch with oil pressure is if it drops alot and temperature is rising, that means your losing oil. the good thing about these trucks is its easy to glance over, as opposed to newer vehicles with idiot lights that don't come on until its too late.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
