05-22-2022, 04:50 PM | #1 |
Active Member
Wtb axillary fuel tank retaining nuts
WTB retaining nuts for my axillary gas tank for a 1970 CST/20. As you can see in the attachment, I damaged mine removing them.
05-22-2022, 08:43 PM | #2 |
Re: Wtb axillary fuel tank retaining nuts
I’m in the same boat. I think at least 2 need to be replaced. I may end up machining some. Let me know if you come up with any extras, and I’ll let you know if I decide to start marching them.
__________________ '68 K10 496/465/205 |
05-22-2022, 09:28 PM | #3 |
`I needed a set a while back , hung a flag out on the forum and turns out another fellow needed some too. He had good original one and found a machine shop to make a few sets. Turned out real nice and the price was fair. If you run up against the wall I can contact him and get the machine shop info for you.
05-22-2022, 11:12 PM | #4 |
Active Member
Knuckle-nurse,
Thanks for the potential lead. I will leave the WTB onb hear for a a week or two. If nothing pans out, I will need the information that you talk about. There may be demand for these. Notice the other post before yours. Thanks Rob |
05-23-2022, 02:39 PM | #5 |
I need some too. Also need the long bolt that they attach to.
72 chevy 3/4 ton 4X4 |
05-23-2022, 02:43 PM | #6 |
Yeah I have a couple of the long bolts that are just rotten beyond repair as well. I was planning on threading some 7/16 round stock and welding the long flat washer to them.
I just got the tanks ready to go in so I need to figure these out in the next week or so. I have a couple of ideas. I’ll update you guys if they pan out, or if they don’t…
05-23-2022, 03:13 PM | #7 |
I don’t need them but if it helps ill take a set because you never know when you need them
05-23-2022, 03:16 PM | #8 |
Active Member
I thought I was the only one who was crazy enough use my axillary tank...guess I was wrong.
Looks like we may need to get in touch with the guy who made the retaining nuts. |
05-23-2022, 03:39 PM | #9 |
Yeah I was shocked to log in and see someone else needing them as well today. I found a couple old threads on them but it’s been a while since I’ve seen anything posted on them.
I wasn’t originally planning on using them but since I built the 496, I’ve decided I want to have more than 100mi range, maybe they aren’t such a bad idea. I’m thinking I can turn the threaded part of the nut on my lathe and I’m going to attempt to press the washer part from 1/8” sheet using my hydraulic press. Plan B is just turn the flat part too. Either way I’ll weld them together. I’m 87% sure it will result in something useable.
05-23-2022, 10:41 PM | #10 |
I believe those are 7/16x14- 12" carriage bolts with a special washer. I tried to find a supplier but no luck so far.
05-23-2022, 10:49 PM | #11 |
Yeah I couldn’t find them either. I don’t see why just welding that washer to the top wouldn’t get the job done though.
05-23-2022, 10:59 PM | #12 |
That might be the only solution.
05-23-2022, 11:13 PM | #13 |
Might be a good idea to make them out of stainless.
05-24-2022, 08:35 PM | #14 |
The nl2 tank is my 2nd favorite option I am shocked the aftermarket people have not reproduced this tank easy to add to a truck that didn’t get the option and looks good. My favorite option cab lights lol
05-25-2022, 06:19 PM | #15 |
McMaster- Carr has 7/16- 14 x 12" stainless threaded rod. I ordered 3 ...will get some stainless domed caps machined up for the top side.
05-26-2022, 12:48 AM | #16 |
I took mine out and junked them. Thinking who would want these? LOL
05-30-2022, 12:52 PM | #17 |
Active Member
Base,
Pleas keep me posted if you are successful with making the retaining nuts. Thanks Rob |
05-30-2022, 10:38 PM | #18 |
Will do. I didn’t get a chance to make any of the barrel parts today but I do have a line on a pile of 2” dia 1/8” thick stamped metal discs I’ll get this week. Getting my press to do what I want to those is the only thing I’m worried about. The rest is pretty trivial even with my clapped out old lathe. Worst case is I can turn those discs on the lathe too.
05-30-2022, 11:02 PM | #19 |
you posted on my thread regarding these retainers a couple days ago. It is clear my parts are not going to give up without self destruction. if you have time and ability, I could use 3 as well. Of course I would like to offer to compensate you for your time and material.
07-28-2022, 08:41 PM | #20 |
Any update
07-28-2022, 10:05 PM | #21 |
How many are looking for sets of the tank nuts? I had an OKC machine shop machine a set for me and for Knuckle Nurse. I thought they turned out great. If I can get an approximate count I will stop by the shop and see if he would make some more. I would connect you direct with the machine shop if he is willing. Here are what they look like.
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
07-28-2022, 11:01 PM | #22 |
Active Member
Sir,
Put me down for four. Thanks Rob |
07-29-2022, 01:35 PM | #23 |
Can you please put me down for 6. 3 for my tank and 3 for a possible mirror tank of the future.
Thank you |
07-29-2022, 02:21 PM | #24 |
I would take 4.
07-30-2022, 12:09 AM | #25 |
I too would be interested in 4.
