Firewall insulation that actually fits
Looking for input on a pad that actually fits and looks correct.
Any input is appreciated thanks |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Firewall insulation that actually fits
Contact Wes at Classic Heartbeat. He was getting a correct US made repro from a family run operation. The more widely available repro pieces look awful imo.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Dec 2013
Repops , It's what they do .
![]() https://www.67-72chevytrucks.com/vbo....php?p=8825200 http://www.repops.com/product-search...102&yr=26&ne=0
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Mar 2015
I have a bunch of it laying around because it didn't fit. I used the "stick on" cab sound insulation. Likely not as effective for heat as the factory stuff. But at least I could cut it and it fit.
I ordered the repops pad from jegs..
Hopefully it's as good as their reputation |
Order from Wes if possible..I think he sells the best USA made pad...
The Jegs/repops numbers are CT1190 for ds , CT121 for 71&72 center and CT120 for 67-70 |
Got the repops insulation installed and between better quality and more experience it fits great...thanks for the heads up.
What was the total cost? How many pieces is it? AC or without AC?
![]() Join Date: Jan 2012
How close is the quality of the repops to that of the original pads? Could you show any comparison or installed pics? Thanks.
![]() Join Date: Aug 2018
Does anyone make them for factory air condition? I can find the passenger side without ac but no luck for the ac truck
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. Last edited by CarlsLQ9SS; 06-08-2022 at 08:49 AM. |
^^^I don't believe there is a mat for passenger AC trucks, thats why they can't be found. I seem to remember coming to that conclusion a few months ago when I looked.
#15 |
![]() ![]() Join Date: Sep 2008
I'm late to this party. Repops pad made in the USA.
#16 |
Thanks Larry, looks like nice stuff. Would you say the quality & fit is on par with the OEM stuff?
#17 |
I was very happy. I used original retainers.
#18 |
Nice, do you remember where you ordered them from?
#19 |
Has anyone used dynomat and then tried installing the pads as well? Do they fit and stay where they need to?
Thanks!
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
#20 |
I used sound deadener on my fire wall and covered that with a pad from GMC Pauls. It worked like I expected, very well. I opted to to use SS button head bolts to secure the pad, but that was just for a fancier look from the engine bay. The OEM retainers would work fine to. They have more than enough reach to accommodate the extra thickness of the sound deadener and then some.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
