Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-04-2022, 11:12 AM   #1
CWW
CWW's Avatar
Welder
I am in the need of a welder to start my sheet metal repair, I do have a Lincoln stick welder but that is not ideal so my question is what has everyone had the most secess with wire feed or tig?
CWW is offline   Reply With Quote
Old 06-04-2022, 11:55 AM   #2
Sheepdip
Sheepdip's Avatar
Re: Welder
More bang for your buck right here. A couple of years ago I started building my automatic gates for my property and my Old Miller went south, it was cheaper to replace it than repair it.
I'm an old guy so I was not going to spend big bucks on a welding machine, I found this Klutch Brand thru Northern Tool. It does Stick, Tig, Wire Feed and comes with an Aluminum Spool Gun.
It is dual voltage 110-220 will weld Sheetmetal right on up to 3/8 material
https://www.northerntool.com/shop/to...3067_200833067
Sheepdip is offline   Reply With Quote
Old 06-04-2022, 12:06 PM   #3
jocko
jocko's Avatar
Re: Welder
I've gotten reliable service out of mydual voltage Millermatic 211. It's never broken on me, but Sheepdip makes a good point - it does come down to how much you want to spend up front - I'd also throw in that you'll probably want to consider how often you intend to use it AFTER this project - that can also affect your decision on how much you are willing to invest.
Old 06-04-2022, 12:09 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Re: Welder
For sheet metal and 1/4" and smaller, Hobart 140
https://www.amazon.com/Hobart-500559.../dp/B009X43F38
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-04-2022, 12:45 PM   #5
mr.mud1
mr.mud1's Avatar
Re: Welder
i had an old Lincoln stick welder,bought a 180 Lincoln mig and never used the stick welder again.i love my 180 Lincoln mig.they go on sale here all the time,now i'm looking at a 210 Lincoln MP but as already said,how do you plan to spend and will it get used as time goes on?an old friend of mine who was for 30 years,a welding shop teacher advised against a tig years ago when i asked,not that a tig won't do it but all around general work,i think you'll find more use from a mig,all the brand name welders are good,which ever you decide on.
mr.mud1 is offline   Reply With Quote
Old 06-04-2022, 12:49 PM   #6
BASE
BASE's Avatar
Re: Welder
It's amazing what these inverter machines can do with 120V anymore. I think my 211 can keep up with the old syncrowave in terms of amperage.
If you want a machine you can grab and weld stuff together for the next 20yrs or so I'd buy a big name machine. If it's just for one light gauge sheetmetal project then any of the smaller inverter machines will probably be fine. Just check reviews and make sure the consumables are available.
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 06-04-2022, 01:14 PM   #7
Big Kev-O
Big Kev-O's Avatar
Re: Welder
I have never taken a welding class and had no experience welding when I deceived to watch a few YouTube videos and give it a try. I filled the gas tank hole and the mirror holes easily with my Hobart 210 mig. I tried TIG welding but the learning curve was much faster with MIG. I don’t think you need a fancy welder just to do body work, one of the budget brands would do the job. Just get a welder and go for it!
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 06-04-2022, 01:16 PM   #8
Accelo
Accelo's Avatar
Re: Welder
I have had too many issues with inexpensive inverter machines.
I would purchase the best Mig I could afford.
Easy to learn with excellent versatility.
I have a 110V Lincoln that has served me well for decades.
Accelo is offline   Reply With Quote
Old 06-04-2022, 02:15 PM   #9
truckster
truckster's Avatar
Re: Welder
I don't think you can do better for the money. And even though it's only rated to 1/4 inch, don't be fooled. I've done 3/8 with excellent results. You just need a good chamfer and access to both sides.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 06-04-2022, 02:55 PM   #10
CWW
CWW's Avatar
Re: Welder
I need to retire the Lincoln stick welder it was my grandfather's and he taught me how to weld with it. I like the idea of the 3 in 1 and the duel voltage. I won't be doing a lot of heavy welding anymore soa smaller one should do the trick
Old 06-04-2022, 05:24 PM   #11
LS short box
Re: Welder
I've had a Miller 211 auto set for 15? years and it's worked well. Dual voltage is nice if you really have to burn something in.
Old 06-04-2022, 08:41 PM   #12
NJ68stepside
Re: Welder
This is what I bought
POWER MIG® 140 MP® Multi-Process Welder
Part #K4498-1
Comes with mig setup. Need to buy the tig and stick connectors
https://www.lincolnelectric.com/en/Products/k4498-1
Please be patient. I’m a ford guy. This is my 1st Chevy.
Previous cars:
1973 mustang convertible
2003 mustang Mach 1
Now building resto mod 68 C10 step
NJ68stepside is offline   Reply With Quote
Old 06-04-2022, 11:14 PM   #13
HO455
HO455's Avatar
Re: Welder
As stated the learning curve for TIG is much higher and the process is somewhat slower. Especially for beginners.
One thing to consider with multi-process welders is that you will need different gases for MIG and TIG. The multi-process machines will take up more real estate for the accessories and tanks.
Welders for the most part brand names usually mean a better quality machine and a better warranty. Fortunately there are lots of reviews to read and watch. The better reviews will discuss things like lead connections, cooling fans, circuit board construction, in addition to the basic specifications and how the machine "feels" when it is welding.
Now the "feel" of the welder is somewhat esoteric and based on personal experiences it may not mean much to the beginner but, it can help pick a quality welding machine when lots of reviewers have similar opinions of the machines "feel".
Buying through a local business usually means you can try the machine before you buy. In addition many times local distributors have free classes that come with the purchase of a new welding machine.
Auto body sheet metal welding is harder on the wire drive and electrical components as you have to spot weld all the seams. The starting and stopping of the welding process puts extra wear on the machine. Once again a quality machine will pay off in long run.
RIP Bob Parks.
Old 06-04-2022, 11:34 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Welder
Primeweld tig225x
Kids been using it up for a year.
Old 06-05-2022, 08:23 AM   #15
Re: Welder
I have an old Lincoln SP100 110v welder. For sheet metal it is great. Believe it or not, Harbor Freight has some good ones to get you through. I like this guy and he is pretty straight on his evaluations of things.
https://www.youtube.com/watch?v=rwH3yoSHTmQ
Old 06-05-2022, 02:49 PM   #16
Grumpy old man
Grumpy old man's Avatar
Re: Welder
The OP lives in the middle of NOWHERE even close to a city , Buy a Hobart or Lincoln welder that it's easy to buy replacement parts , He'll still have to buy/rent a tank and refill it and wire I'd be looking for the closest welding supply company before deciding on any welder and buy what they sell .
Old 06-05-2022, 04:49 PM   #17
LS short box
Re: Welder
Just a note in regards to gas bottles. I have a large bottle on my welding cart. But since you always run out of gas on the week ends I have small bottle as a spare. Also at least around here where ever you rent or buy your bottle from it's the only place you can get a new one when you run out of gas.
Buy a good cart that has shelves below so you can store welding supplies.
Old 06-05-2022, 06:35 PM   #18
Sheepdip
Sheepdip's Avatar
Re: Welder
I, for the most part, run Flux Core wire and save the gas for hard wire applications when you need a little more neatness to a project
Old 06-05-2022, 08:53 PM   #19
68 C10 Driver
Re: Welder
Ok, I'm the cheap guy of the group. I bought a Flux 125 from Harbor Freight when it was on sale for $99. I then converted it to a DC welder and it welds like nobody's business. Great penetration, very little spatter. I have done all of my cab welding with it...cab corners, inner and outer rockers, floor patches, and under dash cowl repairs.
That cheap-azz welder is still chugging along. Just thought I would share.
68 C10 Driver is offline   Reply With Quote
Old 06-05-2022, 09:43 PM   #20
May70
May70's Avatar
Re: Welder
I have a Hobart 210 and it has been great. Its dual voltage but I only run it on 220 because it opens up the lower range selections it seems. I can really dial it in well.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 06-06-2022, 02:05 PM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Welder
I have a Lincoln 140C and love it. I liked the 140C because the dials don't have presets in them, and you can fine tune a little better.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-06-2022, 06:38 PM   #22
CWW
CWW's Avatar
Re: Welder
Thanks guys I think I talk to the company that comes to the pasta plant and see what they offer I talked to the maintenance manager and I can get my name on the list and they will bill me for the gas at a employee discount this might be my best bet for service
Old 06-07-2022, 10:10 PM   #23
mongocanfly
mongocanfly's Avatar
Re: Welder
I started out many yrs ago with a Lincoln 220 stick...then went with a Miller 235 stick
From there I moved to a Hobart 185 mig..been using that for near 30 yrs.. its starting to act funny and I fear it's near its lifes end
Probably gonna catch it here, but I recently bought a Vulcan 220 mig/tig/stick.. will run on 110 or 220v
For the price , this is a unbelievably good welder.. at harbor freight...I know I know..
They just sell it, they dont build it..
I work Industrial maintenance..at work they replaced several defective Miller tig rigs that cost over $3500 each with the Vulcans..
I've never tigged much, but I tig welded up my entire stainless exhaust system on the IH.. I'm impressed
If you go tig, you'll need 100% argon...on mig you'll need a mix 75/25..
So if you want both you'll have to have 2 bottles
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-07-2022, 10:54 PM   #24
Dead Parrot
Re: Welder
Another Lincoln 140C owner. Have yet to do the vehicle body repairs I originally bought it for. Have built two deer feeders and a stand for a deer blind plus several smaller projects.
It says it will run on a 20A 120V circuit. But if you set it for near full power, you will often pop that 20A breaker. It really wants about 25A at full power. Plan on installing a 30A circuit and breaker. Haven't tripped the 30A breaker even on full power runs.
Supposed to be able to use CO2 for shielding gas in addition to the normal 75/25 mix.
Dead Parrot is offline   Reply With Quote
Old 06-11-2022, 10:44 PM   #25
crushermechanic
crushermechanic's Avatar
Re: Welder
I have the Vulcan 215 mig from HF and love it. It uses Tweco consumables. I think it welds as good or better than the Miller we have at work. I have welded up to 1/4 perfectly. I also run it on 220.
crushermechanic is offline   Reply With Quote
