Old 06-03-2022, 11:53 AM   #1
1774btcrew
1774btcrew's Avatar
Does anyone make stainless steel braided brake lines for a 1987 r30?
I have done some checking(maybe not enough) but haven't seen anybody that has any available. Any suggestions would be appreciated.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-03-2022, 12:41 PM   #2
66gmcguy
Re: Does anyone make stainless steel braided brake lines for a 1987 r30?
For legal reasons, I advice you not to do anything that I suggest because modifying brake systems is dangerous and potentially life threatening and should only be done by experienced mechanics...
That being said, in the past, I've just bought -3 AN to inverted flare fittings to attach to existing steel brake lines, then bought appropriate length -3 AN brake hoses that are already assembled and it's worked for me. It's not as ideal as brake hoses that have the correct fittings on them already, but it works. I think there are some hoses out there that have banjo fittings on them already. If you don't see the correct size banjo fitting on a hose, you can get -3 an to banjo fittings by themselves. See below.
https://www.summitracing.com/parts/rus-657042
https://www.summitracing.com/parts/hdt-lf-012
If you go this route, I advise you to only use Russell branded brake hoses. They are superior to others brands.
66gmcguy is offline   Reply With Quote
Old 06-03-2022, 01:15 PM   #3
JJH Jimmy
JJH Jimmy's Avatar
Kore3 will custom make whatever you need.
http://www.kore3.com/categories.php?cat=10
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-04-2022, 05:26 PM   #4
dieseldawg142
dieseldawg142's Avatar
i put skyjacker stainless steel braided lines on my crew 12 yrs ago, zero issues and DOT approved
https://skyjacker.com/shop/category/brake-line/
dieseldawg142 is offline   Reply With Quote
Old 06-04-2022, 05:31 PM   #5
1774btcrew
1774btcrew's Avatar
Are they a direct bolt-on?
Old 06-04-2022, 09:10 PM   #6
dieseldawg142
yep
came with everything too (washers, banjo's...)
