#351 |
Re: my build thread
Very Nice!!!
![]() Serious Skillz!!! ![]() ![]() ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#352 |
Re: my build thread
got my lowers drawn, ill work more on the jigs tomorrow... the dimensions in them are modified to fit my application. The ball joints are moved an extra 3/4 of an inch forward to compensate for the fact that my cross member cross shafts are parallel and the factory frames are tapered, this will also keep my knuckes kicked back just a hair, ill also be able to play with that with the placement of my upper mounts. still working on the upsweep and ball joint angles...
just waiting on tubing to bend... going to order it from the same place in a smaller cut length from the same company to try and get it quicker, as the steel shop in town is waiting on a 20 footer. ![]()
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#353 |
Re: my build thread
little news on the build, still waiting on back ordered tubing, i stuck the rear end together and did some metal finishing on the corners, thats about it, But I did pick up a new toy to aid in the build.I should be tooled up enough with this and the tig to be able to do whatever I need to at home from now on, lets blaze
#354 |
Re: my build thread
Sweet looks good and nice new toy
#355 |
Re: my build thread
Nice finish work. Can't get any finer than that. Smooooooth.
Them 211's are great. |
#356 |
Re: my build thread
Smooth as silk! Beautiful job!
'58 Apache |
#357 |
Re: my build thread
Very nice fab work.....great build.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#358 |
Re: my build thread
Sweet welder! I just got the same one.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
#359 |
Re: my build thread
killin it man!!!! i really dig your work
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#360 |
Re: my build thread
Love the new toy and the work is great also
#361 |
Re: my build thread
no new info on the build but i worked on a welding cart today for the tower of power... Im still in a 1 car garage so space is at a minimum.
#362 |
Re: my build thread
not a whole lot of new news on the truck, got my new mounts in from Energy. Also figured out how to mount the uppers, now ive been working on the tabs to hold them and also make them fully adjustable and also good looking. Steel came in for the lowers and ive got my buddies hydraulic bender in the shop to start on them.
![]() ![]() also finished this cart finally ![]()
#363 |
Re: my build thread
Decided to build some new control arms that fit the application better. Built out of 1 1/4 .180 wall DOM and fully tig welded. Hopefully ill be making more progress soon, have a few irons in the fire as of now to take care of
#364 |
Re: my build thread
Diggin that A arm.
#365 |
Re: my build thread
Thanks Bomp. Been getting a ton of work done on the truck finally, just not enough time to post, so ill catch everyone up with this one.
Got my passenger side rocker replaced, the drivers will be here this week, I ordered them from Brothers and they fit great. Decided to take out all my body work around the drip rail because it was failing due to poor prep work on my part. Spent a lot of time re welding it all and getting it smooth. I hired a guy to come start smoothing the whole cab out. He has the drip rail, fiber glassed, bondo'd, and spot puttied, and is almost all smoothed out. Also ive got the bottom of the cab coated in chassis saver. As for the fab work, the front of the truck is done. Did a bunch of figuring with the lowers, then machined my ball joint sleeves, and made the jig. The joint sits on a 13* angle, and both arms are built on the same jig, just by moving the locating slug and bolt to a different hole. I need to change the upper mounts just a bit for caster/camber and ball joint accommodation, but overall im very happy with how its coming together. Once the front is done ill get it all up on a frame table and connect it to the rest of the frame ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#366 |
Re: my build thread
Front end and cab looking great!!!
I'm interested to see the drip rail conversion done.
#367 |
Re: my build thread
awesome work man!!! really make me want to try to build some tubular control arms!!
#368 |
Registered Loser
Re: my build thread
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#369 |
Re: my build thread
Excellent work !
#370 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: my build thread
Very nice work.
I have often thought about building my own control arms. Yours look sweet!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#371 |
Re: my build thread
Well no updates on this thing. I decided to make some serious life changes and take my career somewhere new where I hope to go further. The truck was un able to make the trip. The frame cab and bed were sold. I decided to keep all my front end stuff and keep my 66 in hopes of bringing it to southern Washington one day to finish it.
#372 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: my build thread
Do you have a new build thread on the new truck?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
