06-20-2022, 12:15 AM | #1 |
Transmission Lines/headers
Can't use the stock tranny lines with my new headers. I'm thinking of using a after market cooler that I can mount to the side of the frame. I've seen the tube type and the small radiator type. Which would be the the or easter type ?
06-20-2022, 06:46 AM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Transmission Lines/headers
I run headers on both my 72's, one is a big block and dont have any clearance issues. Installing an isolated trans cooler is fine unless you live in region where it gets cold because the "cooler" built into the radiator actually warms up the trans fluid in cold conditions. Most stand alone coolers attach to the front of the radiator meaning your going to have to run lines up there to it. And many coolers incorporate the internal cooler in the radiator. So what I'm getting at is your going to have to run new cooler lines where ever you choose to mount it. Why not just buy a set of new pre-bent metal lines to the radiator? Maybe a pic of your problem would help us understand the problem...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-20-2022, 09:14 AM | #3 |
Not sure why the stock lines won't work. You can bend them fairly easily if you just need a little clearance. Alternately, it is relatively easy to bend new lines. That is what I had to do as the previous owner had over tightened and destroyed the ends.
Just buy the 3/8" or 5/16" brake lines (can't remember the size) in the correct length and bend to fit (use a bending tool for tight bends-you can borrow them from the parts store). |
06-20-2022, 10:07 AM | #4 |
I did buy pre bended lines for the tranny. Tried putting them on with the headers on. I will remove header to have more room to work with and see how that works out. Thank for the input and info.
06-20-2022, 11:08 AM | #5 |
If the tranny lines are close to headers in one area even after bending them some to clear....you can use a heat wrap like what Vibrant Performance makes for that section of line. It is split loom but made of heat wrap and comes in various ID (3/8", etc) by 4' length. Summit, etc carry it
If using a higher than stock stall TC, plumb in a additional tranny cooler typically mounted in front of radiator or below it if its a cylinder type cooler. The return line would go to the "in" side of the AUX cooler and the "out" line of AUX cooler runs back to the return port of trans. The path of line is your choice. |
06-20-2022, 11:30 AM | #6 |
From what I have read on aftermarket transmission coolers: They recommend using in conjunction to the built in radiator coolers...
Just a note to look into in-case you need. |
06-21-2022, 08:21 AM | #7 | |
It takes a fairly large external cooler to replace the internal one.
06-21-2022, 01:11 PM | #8 | |||
"I ain't nobody, dork."
Gary
