View Poll Results: Can this easily be done
swap whole axle or spacer delete 0 0%
cost effective 0 0%
Voters: 0. You may not vote on this poll
Old 06-24-2022, 04:28 PM   #1
goat68
K30 Cab chassis Front axle spacers
I have a 88 Crew Cab Cab Cassis dually ( narrow dually rear end ) 4 x 4 that I am lifting a rebuilding and I love the narrow dually rear end ( always gets a double take ) Bur I want to know if I can remove the front axxle dually spacers to use regular style 2500 front wheels dished out and not in like the dually. I am doing a 6" lift and doing custom dually rears to hoefully closely match the front standard 2500 dished wheels. Long question short what do I need to do
goat68 is offline   Reply With Quote
Old 06-24-2022, 08:53 PM   #2
52napco
Re: K30 Cab chassis Front axle spacers
You will need to replace the hub and rotor to srw type.
52napco is offline   Reply With Quote
Old 06-25-2022, 11:24 AM   #3
kipps
https://www.hillbillywizard.com/dana...na-60-srw-hub/
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-26-2022, 09:19 AM   #4
I always wanted to custom-build front Budd wheels to be wider, like on Heavy Duty trucks, to run wide tires and have wheels match
