05-18-2022, 06:47 PM | #1 |
The Rotten Pumpkin
I've owned this truck for like 12 years now its always been the summer DD back then I never thought much about it. It was just fun and I didn't care if it got door dings. When I first got it she was a straight 6 three on the tree but the clutch went bad so the small block and 700r4 I had sitting around went in. Now days its a 350 with a little cam 221/221 on a 108, Q jet on a iron intake, some summit heads 72 cc chambers. Still got the 700r4 but the reared has been swapped to a '71 12 bolt with 3.08 gears (the slightly wider axle helped run the 8" rims out back). These days she mostly gets used for longer highway trips.
05-18-2022, 07:04 PM | #2 |
Moderator
Re: The Rotten Pumpkin
Nice truck. Have any other plans for it?
05-31-2022, 06:17 PM | #3 |
Thanks. Not really I just use it, though at some point a front sway bar would be nice
05-31-2022, 11:17 PM | #4 |
I like it! A front sway bar is definitely a good modification. It improved the drivability of my truck a ton
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-05-2022, 06:19 PM | #5 |
06-11-2022, 06:03 PM | #6 |
Took the pumpkin out to the Tin Butchers Scrap Drive today. Pretty good show considering the threat of rain
06-27-2022, 07:28 PM | #7 |
The pumpkin made the trip down state to the Street Machine Nationals. Tons of cool stuff great venue too.
