Old 06-28-2022, 08:17 AM   #1
A1971Blazer
A1971Blazer's Avatar
Lower Bump Stops
I found lots of articles about them but no secrets to getting them installed?
The front suspension on my 68 had drop springs and was sitting on the bump stops....and they were shot.
In the process of upgrading to disc brakes, I removed the drop springs and went to drop spindles...got them in last night and mocked up enough to put the wheels on and check the stance...perfect!
Now I have about 3" of suspension travel and I want to put new bump stops on.
I tried several ways to get them into the slot...to no avail...
Is there a trick that I don't yet know?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-28-2022, 08:45 AM   #2
Jason Banks
Jason Banks's Avatar
Re: Lower Bump Stops
They are certainly a PITA. I have put WD40 on the control arm and the bumpstops in the toaster oven(or I've heard hot water). Then work fast while the rubber is pliable.
Jason Banks is offline   Reply With Quote
Old 06-28-2022, 03:48 PM   #3
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I used liberal amounts of grease on the bump stop and then loads of elbow grease with a hammer and blunt screwdriver to slowly put mine in.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 06-28-2022, 04:02 PM   #4
A1971Blazer
I'm racking my brain trying to come up with some kind of quick easy-to-make tool
maybe it'll come to me in a dream....
1967 C10 Step side
1968 C10 Step side
Old 06-28-2022, 04:54 PM   #5
67C10Step
67C10Step's Avatar
Ok, at the risk of being made fun of I got mine in without too much trouble using the following method and tools.
Tool - One of those blue plastic trim tools, the one with the rounded end.
Hot water - soaked them in hot water to make them a bit more pliable.
KY jelly - added a bit to the bump stop "tab" and some to the area on the control arm.
Tilt the bump stop up and put the edge of the tab in about the middle of the slot, work both sides in with the trim tool and then push/slide it into place while working both sides with the tool.
Didn't take me 5 minutes per side.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-28-2022, 05:00 PM   #6
Jason Banks
If you got them installed in 5 minutes per side, nobody is gonna make fun of you, no matter how you did it.
Old 06-28-2022, 05:02 PM   #7
Jason Banks
After having to reorder some because I ripped the tab off at the bottom(partially) I went to using a trim tool that is rounded on the the ends, mine are orange though.
Old 06-28-2022, 05:15 PM   #8
67C10Step
67C10Step's Avatar
I guess I should admit to a couple of failed attempts that put me searching for a better method. So, total time I guess I was way above 5 minutes per side.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-04-2022, 08:15 PM   #9
4LUG39
I just did mine, I dropped them in boiling water for a few minutes. While they were in the water I set up my lower control arm in my press. I put a good amount of grease on the opening and put them in place. I pressed them down until they started to squeeze in then I used a trim tool and screwdriver.
Ain't no way in the world I'm going out that front door.
69 SWB Fleetside 327/5spd
76 blazer 383/700R4
95 2Dr Tahoe 5.7 4x4 LT
4LUG39 is offline   Reply With Quote
