85 dual tank gage question
I believe the printed circuit board went on my 85 as the fuel works sometimes and the others not at all . I would like to install a fuel gage in place of the volt gage in this gage pack . My question is what wire in the harness running to the plug at the printed circuit board is for the gage . My thinking is if I get a new gage and tap into the wire I should be able to run one aftermarket gage for both tanks . I plan on doing the circuit board this winter and fix it properly then
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Dec 2009
Re: 85 dual tank gage question
Mark
Here is a link from a Member (Vendor) on the board of his wiring diagrams. P.S. I just purchased a vinyl floor from him (It was A great purchase) Anyway, here is the Link ![]() Link: http://forum.73-87chevytrucks.com/sm...?topic=11766.0 Hope this helps.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#3 | |
Moderator
![]() Join Date: Oct 2008
GM wiring diagrams are available right here. Look in my signature. The other thing to look at is the dual tank theory of operation thread. https://67-72chevytrucks.com/vboard/...d.php?t=754061
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I'm not good with diagrams specially wiring . But from what I can tell the #30 on the plug is to the gage. I'll just trace up the harness to find the plug i assume it's on the firewall .
Ordered the gage auto meter 2316 for 65-97 gm . Be nice not to have to use mileage for fuel stops . I’ve had to switch over on the road not fun at 65 mph
#6 | |
Moderator
You have a 1985 with the motorized valve. Read post #2 in that thread. Post #2 covers 1981-1991.
I see that now thanks . I guess I need to tap the B pin ?
Moderator
A & C come off the tank senders to the switched contacts of the SPDT switch inside the valve.
B is the common terminal on the gauge switch inside the valve and the B wire terminates to a molded rubber disconnect on the RH frame rail. The wire runs from there up to the bulkhead plug under the brake booster. Honestly it's usually not difficult to diagnose and fix the fuel gauge in the dash. The tank ground wire is one of the more common failure points in the 1973-1986 fuel gauge circuit. It either gets left off by someone replacing the tank or the wire rots off the ring terminal at the frame or the .250" disconnect on the sender locking ring rots off the wire. If the stock fuel gauge is nailed at 3:00 you likely have a bad tank ground wire. Easy to test and not awful to correct. Take a set of jumper cables and attach one end to the frame and the other to the pinch weld on the selected fuel tank. If the fuel gauge needle suddenly comes to life with the KOEO (key on engine off) you'll need to fix the tank ground wire between the frame and the sender locking ring. Many moons ago I attached an alligator clip jumper wire from the frame to the pinch weld on the tank on my 78 GMC to get me by for a couple weeks til I had time to fix the problem properly. The other thing that'll nail the fuel gauge at the 3:00 position is an unplugged sender wire or damage to the wires in the sender circuit. There's only three of them and they're fairly accessible. If the valve is unplugged you've likely found your problem. I've commonly seen the sender wire get chowdered up where it runs along the frame rail. It's either unplugged from the harness wire that runs up to the bulkhead plug under the brake booster or something happened to it between the valve terminal B and the molded rubber round pin disconnect on the frame rail or right after the disconnect. None of that is difficult to repair. No amount of brandy new fuel gauges will read anything without a good tank ground and good sender wires from the tanks all the way to the gauge.
#9 | |
Moderator
If none of your gauges and lamps are working the first place to look is the ignition power and the ground wires to the cluster.
Ignition power is pinkish red with a black stripe. Look in the wiring diagrams for the fuse that feeds the cluster. It's marked INSTR LPS and it should be 5A. The other fuse to look at is the 20A IGN/GAU but that one will likely cause other issues. Ground is black. I've found the main instrument cluster ground unplugged from the buss bar above the parking brake pedal more than once. Easy quick fix.
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-29-2022 at 03:52 PM. |
The senders are fairly new as is the switch . I tried the ground to frame no response . I doubt I would have a ground issue on both tanks at the same time.
This the bulkhead you referred to? No other connections there .
#12 | |
Dash Lamps are working fine
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-29-2022 at 04:06 PM. |
Moderator
Only one fuel gauge is connected through at a time. If the valve is working then that's unlikely to be the problem on both tanks.
The bulkhead plug is the big square Packard plug that most of the wires pass through into the cab. It's near the booster. The 16ga pink wire next to the light blue wire at the bottom left on the pictured bulkhead plug is Circuit 30. Circuit 30 is the GM name for the fuel gauge wire from the frame disconnect that plugs into the valve sub harness wire to valve terminal B. The bulkhead plug is shown in the first full page of wiring in the 86 wiring diagrams. You can backprobe the bulkhead plug with a T-pin to hook up your meter. OTOH disconnecting the bulkhead plug isn't rocket science. Unscrew the bolt and the plug comes apart like Lego blocks. Unplug the battery before you disconnect the bulkhead plug. I'd take a meter and check for continuity from the bulkhead plug to terminal B on the valve plug. If you don't have continuity you've found your problem area. It's usually chewed up down under the cab near the valve subharness disconnect.
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-29-2022 at 04:21 PM. |
#14 | |
#15 |
I just checked it has continuity from the block to the b pin on the fuel plug so one item off the list . What I’ll do is disconnect the pink wire from the harness plug at the firewall and run it to the new gage . I’ll have it Friday so I’ll know by Sunday if it’ll work.
Thanks for the help hatzie
#16 |
Moderator
I'd clip the circuit 30 wire 6" from the instrument cluster plug and hook your gauge up there.
No wires to drag through the firewall just across the dash. Download the 86 wiring diagram. It'll show the position of the circuit 30 wire on the instrument cluster plug. It's in one of the corners of the plug. When you're ready to use the dash again solder the wire back together.
#17 | |
#18 |
Well that didnt last long . Turned it off and restarted about 20 minutes later and its sitting at 1/2 tank LH or RH
But the ac is working well
#19 | |
I am so sorry that I posted that info. Hope you get this issue resolved Mark. Just keep the tank full ![]() And I hope to see you at the Show ![]()
#20 | |
I've been writing down the miles i fill at and pretty much know when to get gas . Would be a real problem if i had only the one tank. I have had to switch over at highway speed it's not fun .
#21 | |
Moderator
Why? You're being helpful. That's what we're here to do.
![]() Quote:
The tin plating on Weatherpak tower terminals to the valve corrode if they're left unplugged. The brass Packard terminals corrode when the black dielectric goo that GM sprayed the plugs with degrades. Caig DeoxIT D5 and a set of carburetor cleaning brushes might be a worthwhile investment. I've seen small diamond files for cleaning Canon plug terminals but I figure if they're that corroded it's time to replace them. Carb Cleaning Brushes on Amazon I can get Deoxit D5 at a guitar store. Musicians use it to clean the plug contacts on their guitars, keyboards, mics, and amps. I use it on other electronics. I used to pick it up at a local Radio Shack but they're disappearing. :-( Be sure to get the DeoxIT D5. They make a "fader" cleaner and lube for potentiometers that won't work as well on connector terminals. Once the bulkhead terminals are treated with Deoxit, scrubbed some, and sprayed again it wouldn't hurt to add some fresh dielectric grease. CRC 02083 Spray Silicone Dielectric Grease would be a reasonable choice. You can probably use a lube straw on this to reach into the female terminals and treat the bare wire at the back of the connectors. I wish I knew what that black dielectric grease that GM sprayed into them on the assembly line was. It protects things for half a century and more. I've taken apart the bulkhead plugs on late 1960's GM, AMC, and Chrysler cars and found the terminals look like new.
#22 | |
Now I’m a little stumped . The directions on the new gage says to run a ground wire from the back of the gage to the ground on the sender . But I have two tanks guess I could pigtail it . But I’m not sure as to why it would need to go directly from the gage to sender wouldn’t a ground to chassis work ? Since it’s just really measures the current going through the sender .
#23 |
I wired it to chassis ground not the tanks . It’s working
![]() Right full left 3/4
| Bookmarks |
| Thread Tools | |
| Display Modes | |
