06-30-2022, 11:38 AM | #1 |
BMW & ASE Master Certified
2017+ swap vats delete question
2017+ is labeled as e92a ecu, takes 4 Hptuner credits
pre 2017 is e92 ecu and takes 2 Hptuner credits I have only had luck with 2014 flashes on pre 2016 ecu that has vats 1 and 2 patches. Has anyone successfully removed vats from 2017 newer ecu? Contacted HPtuners and it was not recommended to flash the e92 ecu file i have used in other swaps to the new style ecu. All pin outputs are pretty much the same except the fuel pressure sensor, and a few other extra wires that gets de-pinned . It might be standard practice not to just write an entire file from some other ecu, but being a different e92 and e92a could be a problem? maybe able to stat it up this weekend, if not next weekend. Really don't want to waste 200 in credits on the 2017 ecu and turn around and have to buy a pre 2017 ecu and license it too. thanks, Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-30-2022, 06:15 PM | #2 |
Re: 2017+ swap vats delete question
I just finished a 2018 swap and it worked with no problem. But you also have to disable the starter diagnostic, I didn't do that at first and it didn't start, but afterward it was all good. The 4 credits part does kind of sucks though, but what can you do...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-30-2022, 09:40 PM | #3 |
pm sent
