Old 08-01-2004, 07:53 PM   #1
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
WTD: Aux. leaf spring for coil rear (3/4 T)
Looking for a set of original leaf helpers for the 3/4 T coil rear on my truck. Don't care if they are rusty, long as they're usable and cheap.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-01-2004, 08:04 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I have a set under my parts truck.
Can you tell me, are they bolted or riveted on from the factory? Otherwise, I will have to go look to see and the truck is in 6 feet of chigger and copperhead infested Johnson grass.
If they bolt in, I'd sell mine cheap.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-01-2004, 11:10 PM   #3
I'm looking at my 70 service manual and it looks like the bracket for the spring is bolted on, I can't really tell. The springs are held to the bracket by one big bolt, I know that for sure.
RJD
Old 08-01-2004, 11:50 PM   #4
jostrans68
Jostrans68
jostrans68's Avatar
not mine but here
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 08-02-2004, 08:16 AM   #5
Huck
Huck's Avatar
coil overloads
The factory coil overloads are bolted onto a bracket which in turn is bolted onto the frame. I have seen them with sindle leaf or 2 leafs depending. The e-bay picture is correct however it leaves out a critical piece and that is the overload needs to have the special lower shock mounts with the rubber pad that the spring contacts under load. They bolt on the bottom of your rear control arms. Without them your overlaods don't contact anything and are useless. The pain in the butt is getting those brackets off as the big U bolts that support the control arm to axel connection go right through these lower shock mounts. Sometimes it is easier to cut these big U bolts then trying to unbolt them with rust. And sometimes it is a bugger to get the U bolts to pull through the control arms as they tend to rust in real tight. Good Luck--Huck
Huck is offline   Reply With Quote
