#1151 |
Re: My Dusty 71 GMCe Electruck
Long weekend at the wrinkle nose garage, Earl has some undo time and a half coming....Happy 4th Gregski.
#1152 |
![]() Join Date: Aug 2014
#1153 |
upper control arm bump bumps
Fun Fact: only reason I opted to run sum is to keep the 2" lowering coil springs from falling out when jacking up the truck |
#1154 |
so guess what? I'm redoing the driveshaft turns out the Lexus drive shaft has the center bearing support bracket on the wrong shaft (differential side instead of transmission side) so it aint gonna work out for me, so three drive shafts later...
I'm gonna post a video explaining all this so please stay tunned |
#1155 |
so I thought I would clean up the center bearing drive shaft support cross member just a tad
yes all that dirt is just from the back side of the center crossmember, wait till you see how I cleaned the other side |
#1156 |
ah yeah, I am not even kidding there were some things stuck so hard I could not get them off by hand using a putty knife nor a flat screw driver
#1157 |
new old bracket fits
#1158 |
well I was driving myself crazy so I decided to make brown things gray
thanks be to a forum member who hooked a brother up with two proper upper coil ear lobes (I'm sorry but once you see them you can't unsee them) |
#1159 |
how many details does my devil have?
#1160 |
there, happy now?
#1161 |
decided to throw sum luv to the threaded nails as well
#1162 |
Wife: "Honey have you seen our aluminum foil, I can't find it?"
Me: "Now what would I be doing with our Reynolds Wrap in the garage, come on now?!" also Me: |
#1163 |
all powder coated and ready for reassembly (and no that one missing washer is not bothering me at all, NOT ONE FRIGGEN BIT, ok, there I said it)
#1164 |
I swear this happens to the same finger every time, can anyone relate?
#1165 |
Hercules Hercules
#1166 |
I like to use a jack hammer to open these cans
Top Tip for best results: Stir it very well... then stir it sum more! |
#1167 |
how much does one can cover?
and what's it look like up close? |
#1168 |
![]() ![]() Join Date: Jan 2005
Busy day! Looking good.
#1169 |
#1170 |
decided to weight this bad boy, this is the 1 1/16" stick (the smaller of the two)
#1171 |
mandatory stare and compare before I go mount the rear boingers back on
#1172 |
so motivated by Bill Bayer I decided to take another stab at the Prius power steering doo dad, I was not happy with it under the dash
Power Steering - Tesla Jeep |
#1173 |
so here we go time for surgery
#1174 |
The Pull-A-Parter 3000
Sketch Level: EXPERT |
#1175 |
American Polack Potrafi
Pull-A-Parter 3000 complete kit with attachments also available in metric |
