Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-14-2022, 03:12 PM   #1
lofly'a
lofly'a's Avatar
Unhappy Overheating!! - Troubleshooting not going well, need input
swapped a '90 350 stock tbi into a 91 S10 Blazer. swap went without incident, but having issue with operating temp. so far we have upgraded to 82-89 corvette radiator, & derale 15" Hi-Perf fan. the temps hover at 210 and will go to 230 in traffic (w/o AC). i even installed 2 electric pusher fans without improvement. been thinking maybe the water pump not flowing enough and or fan not big enough. don't know if the water pump is new or rebuilt. impeller clearance may not be right. i have access to a 17" flex fan so water pump and fan swap is next steps. i welcome any wisdom and/or input.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 07-16-2022, 05:32 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Overheating!! - Troubleshooting not going well, need input
How did you fit a mechanical fan to it? Did you move the engine back or move the radiator in front of the core support? Do you have a fan shroud?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-16-2022, 11:05 PM   #3
lofly'a
lofly'a's Avatar
moved the radiator forward. yes it is shrouded, about 1.5" between rad and fan. i also tried swapping the t-stat and drilling 2 - 1/4" bypass holes in the t-stat w/o improvement. gonna try a diff water pump & fan next (larger diameter) as i'm out of options. i've been more leery of elec. fan setups lately. swapped back to a belt driven fan on my GTO that dropped temps from 205 average to 180-190. i wasted several hundred dollars on a elec. rad/shroud/fan system made for that car with dismal results.
Old 07-16-2022, 11:32 PM   #4
Just call me Sean
Are you sure the fan you used is for a reverse flow water pump? I like using a stock type fan with clutch, I never had any luck with electric fans either. I recently changed the water pump on my truck and it brought the temperature down, I was thinking maybe the impeller was rusted out. I had a van I rigged up with a smaller radiator with no shroud and didn't have cooling problems.
Old 07-19-2022, 05:24 PM   #5
lofly'a
lofly'a's Avatar
WP and fan is correct reverse flow. gonna install a larger diameter fan and change the WP this weekend. the problem is that the temps dont go down even at highway speeds which is indicative of a water flow problem. if temps go down at highway speeds then there is a air flow problem. wish me luck.
