07-16-2022, 08:26 AM | #51 |
Re: Did the 1/2 ton short beds come with a two piece driveshaft?
I don't mean to brag but I just picked up my 5th wrong drive shaft today, lol
this one actually had a '69 tag on it, and my chassis is technically a '69 (the truck is registered as a '71 but let's not split hairs, ha ha) I realize this one comes from a 3/4 ton truck aka a C20 however that just means the shaft would be beefier if you will that should not constitute a different length per say, if you follow my logic two trucks parked side by side, for example a long bed C10 and a long bed C20 would be the same length, no? assuming both had GM 12 bolt butts this is soooo Goldilocks: this one's too short, this one's too long... |
07-16-2022, 08:29 AM | #52 |
I used the Greg-O-matic drive shaft spreadarizer 3000 to divide it in two just for funnsies, mucking up the fine threads in the process
Sketch Level: solid 9 |
07-16-2022, 08:32 AM | #53 |
I also media blasted the yet another variety center support donut mounting bracket plate just for show and tell [and cause I finally got my media master blaster setup where I can see inside it, hee hee, so I am media blastin' everything in sight]
not sure if this is stock or not, maybe one of youz can verify it please [we're looking at you Mr. Keith, ha ha] |
07-16-2022, 11:56 AM | #54 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-16-2022, 11:57 AM | #55 |
One of my buddies at the race track had a T shirt that said:
"That's sketchy even by my standards". I'll have to see if I can get a picture of it. K
07-16-2022, 01:22 PM | #56 |
Gregski. I have a 1968 Longbed 307 4-Speed truck that came with that style bracket. I was going to post a picture of it in this thread earlier, but looked through my pictures and couldn't find a good one of it installed.
07-16-2022, 03:57 PM | #57 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
07-16-2022, 04:26 PM | #58 |
Here is a picture and length of the rear half of the 2 piece drive shaft off my short box. I cut down the front so I do not have the original length to share.
07-16-2022, 11:08 PM | #59 |
so after all that 5th time was indeed the charm, with the help of a buddy we figured out how to mount this bracket, it actually mounts on the transmission side of the trailing arm cross member, I literally had to drill the two holes through the dirt and grime cause they were totally and completely clogged
07-16-2022, 11:15 PM | #60 |
07-16-2022, 11:16 PM | #61 |
thank you so much could you post a pic of your center support donut and bracket, a friend of mine and I have a theory of what the 1/2 tons should look like, compared to the 3/4 ton style
