Old 07-22-2022, 04:56 PM   #1
bennylava
bennylava's Avatar
Is there an oil pressure gauge with 60 PSI maximum?
Hi all. I made the mistake of installing an oil pressure gauge that has a 100 psi maximum reading. This means that it always looks like I have no oil pressure. Back when I had the factory 60 psi oil pressure gauge, this wasn't a problem. The gauge would at least read that there was pressure. I'm hoping that someone makes aftermarket gauges that look nicer, but only go to 50 or 60 PSI.
I know you can buy those factory replacements, but it would look out of place as the rest of my gauges are non-factory.
87 5.7L if that helps. Thank you!
bennylava is offline   Reply With Quote
Old 07-22-2022, 09:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Is there an oil pressure gauge with 60 PSI maximum?
I just googled [ 0-60 psi oil pressure gauge ]...it brought up many choices..try that and pick out what you like
You didnt state ,size/dia, color, elec sender, mechanical sender, or any other info
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-23-2022, 10:31 AM   #3
Pontiac1976
Pontiac1976's Avatar
Nor what brand type you had.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-23-2022, 10:35 AM   #4
hatzie
Moderator
hatzie's Avatar
GM made stock gauges with 0-60psi and 0-80psi. Both senders are 0-90Ω
My tractor has a 0-40psi gauge and I've seen 0-60psi gauges
VDO V350040 is an 80psi oil pressure gauge and they make up to 150psi oil pressure gauges ( I used one on my 1982 VW Rabbit Diesel ) and as low as the VDO A2C59514210 with a 30psi sweep
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
